Remote start bypass module help
Hello, I have a 05 civic ex(auto) that came with 1 key only. To avoid having to get a 2nd key programed, is there a bypass module that works without the need of a 2nd key inside the box? If so, post a link with the part. I found the xpresskit pkall which seems like it's a keyless bypass module. Thank you
Received 1,124 Likes
Rep Power: 190 Re: Remote start bypass module help
for the price of a bypass module you could get a key, call locksmiths and parts stores in you area to get prices/availability.
or if you don't mind having the green key flashing on the dash its pretty easy to override the immobilizer
Can i make a copy of the key that has the chip, use the copy to turn the car in via ignition and leave the chipped key inside the box? Will that create any issues?
Prelude Owner
Is this for a remote start install or are you trying to avoid buying a second key to use all the time in the car?
I have used the xpresskit and it worked great in my 01 Civic.
Prelude Owner
Ok. I didn't like the idea of leaving a key in the car and seeing as I only had 2 also didn't want to give one up. I think I paid 30-40 for the xpresskit.
sijen
01-07-2013 05:41 PM
nweber911
10-21-2012 02:13 PM
roger t
02-25-2009 07:50 PM
954rr coupe
12-07-2006 08:39 AM
