- Question about rear shoulder cushion
- Need info on rear interior trim part
- removing the sponge behind the pedals under the floor carpet
- seat fabric
- Crank Handle Post Needed
- Air Blend Actuator location?
- drain locations and access?
- Interior Door Lock Indicator?
- Just a little heat
- Interior leak around dash
- Aren't sure about ordering new interior door handles
- Replacing heater valve
- 04 Si EP3 - Removing Front Passenger Seat
- How many of these bushings do I need?
- Exact color code/name of dashboard color (Brown/Beige)
- How to safely remove old interior plastic panel
- Question about rear seats key lock in rear deck
- Rocking driver side seat fix
- Sunroof drain hose connector?
- Cloth headliner giving way after cleaning
- Rear Seats Cushion removal
- Drivers side lower kick panel removal
- Gear Shifter Light [solved]
- Tried cleaning with liquid carpet cleaner 3-4 times/ still dirty
- Removing interior part [solved]
- Stain and neglected carpet cleaner
- Faded center of the steering wheel fix
- Flooded Car Rescue
- seat covers for 2002 ex 4 door
- Gas release cable not working, even with cable repair kit
- How to take apart passenger seat track (right track of passenger seat) to fix sliding
- 2001-2005 e-brake with cup holder
- Dash repair
- 2001 civic LX interior headliner replacement
- No dome lights when door opened and other issues
- 2004 VP Inner Door Panel Removal
- It's A Wrap
- 'Secret' recall Civic sunvisors?
- 2002 honda civic EX cluster in a 2005 VP
- Should these items have lightbulbs?
- Adding cigarette lighter port
- '03 Civic EX driver door actuator no power?
- How do I remove my center console
- Leaking trunk
- 03 civic climate control inoperative
- How do I manually raise the sunroof/moonroof into the tilt postion
- What seats are direct swap for 7gen sedan civic?
- civic 2001 ac and cabin noise
- Door lock solenoid
- 2005 4 door car will lock with interior switch but not unlock?
- Seat belt issue
- 02 EX Coupe - Rear Cup Holder - less a .10 cent FIX
- Door panel will not clip back after installing speakers
- Armrest Installation
- How to change gear shift bulb on 02 lx sedan
- Instrument panel bulb replacement
- Cloth to leather seats
- Will 03 Acura el seat fit on 04 civic sedan?
- Driver's door upholstery coming unglued
- Door jammed. seen this before?
- very low airflow (volume) from the dash vents...
- 2002 EX interior bulb sizes?
- Cluster Swap (both Auto Trans, both sedans) from 01 civic ex to 04 civic l
- trying to fix 2 loose parts
- Help with Cup holder/center console replacement
- HELP!! Water leaking from steering wheel
- What are these for?
- Back deck rattle
- back seat, part you sit on
- Are these switches supposed to light up?
- Water Leak
- Water leak inside the car
- How to change front dome light
- 2002 Civic EX Cluster problems?
- heater not blowing heat consistently
- 04 civic ex cluster help please
- 2003 Acura EL Front Passenger Creaking
- Dome light stopped working
- 2001 Civic LX Automatic Shifter Bulb
- Taking dash apart to fix AC?
- 05 Civic No heat at idle and bad mpg
- Rock Forward and Backwards
- Water Dripping on Driver Side
- Fabric/liner on driver's side door is coming off
- Leak somewhere on passenger side
- Swap Seats and Turning Airbag light off
- dome light not working when door open.
- Question on VP Cluster installation
- Looking for an OEM Si shift knob for 06-11
- 2001 civic interior
- AC - No HEAT onlly blowing Cold
- Squeak Noise on Seat when turning
- What the F is vibrating behind the panel?
- how to take headliner and pillars off civic 2002?
- car getting wet on passenger side
- rear deck question
- Interior Reupholstering
- whirling freeway noise
- How Quiet Inside Your Civic?
- the damn driver seat
- stuck gas pedal
- Rear defrost light
- Cold Air on Feet (2k2 civic)
- Burns in upholstry
- cracks in your gauge cluster cover.
- Armrest or Elbowrest?!
- Interior Panels
- Is the armrest too small???
- Metal Shavings in Steering column
- GAP between the roof linner and sunroof's shade
- Frost on interior of windows???
- plastic piece under dash getting in the way of the clutch
- 2001 seats not as stiff as previous generation
- Seat belt not retrackting all the way???
- Back Seat Clicking sound
