Interior Post about Interior parts, seats, consoles, etc
No dome lights when door opened and other issues
Old Dec 4, 2021
Jey NotoAuto's Avatar
Jey NotoAuto is an unknown quantity at this point
Originally Posted by CraigW
Does your "key in ignition w/door open" sound still occur ?? (they are the same piezo unit)
hey guys, I been trying to do some research on a similar kind of problem but I can’t seem to find anything and this conversation was the closest thing I’ve seen relating to my problem. So that beeping sound doesn’t work when the lights are left on and with the door open. Also my key fob won’t unlock or lock the doors, the headlights won’t flash and the horn won’t honk. Also my dome light doesn’t come on when I open my door but the switch is in the correct mode to come on when the car is unlocked or the door is open. Lastly my door switch won’t unlock and lock all doors with the car off but it will with the car running.
Ive checked all the fuses relating to the issue and all of them are intact. I haven’t checked every single fuse in the fuse box though.
does anyone have any ideas, advice or suggestions? I’d really appreciate the help, thanks in advance!
Old Dec 6, 2021
BrotatoChip's Avatar
Super Moderator
Re: No dome lights when door opened and other issues
Moved to a new thread, please don't reply to 15+ year old threads.
Work on one issue at a time, no alarm when lights left on and door opened. I'm going to guess this is just a failed door ajar sensor. Next to the door latch on the body is a little black sensor. Remove it, then use a paperclip or something to jump the two wires in the connector. Do the dome lights then come on?
Old Dec 6, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Yes, this little black plunger sensor can get mangled if a seatbelt latch has been slammed shut by the door, for example.
Old Nov 7, 2023
jbyrd239's Avatar
jbyrd239 is an unknown quantity at this point
Were you ever able to figure this out? I’m having all of the same issues and it started doing this after changing out the radio. Could it be something behind the radio or could something just have gone bad at the time?
Old Feb 19, 2024
K24's Avatar
K24
K24 is an unknown quantity at this point
did you get this fixed and how? Sorry I know I’m responding a little late
Maqcro
Exterior
Oct 12, 2021 04:33 PM
emaxxx4
Mar 16, 2012 09:27 PM
biobot93
Feb 28, 2012 07:08 AM
jbrown59
Feb 21, 2011 07:09 AM
kryal
Oct 23, 2010 06:34 PM
