Interior Post about Interior parts, seats, consoles, etc
2004 VP Inner Door Panel Removal
Old Oct 19, 2021
gatrhumpy1's Avatar
gatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of light
I used to have a Haynes Manual that had a lot of useful information on it, including how to remove the inner door panel. However, I don't have that manual any more. I have one coming to me.
Does anyone know how to remove the inner door panel for a 2004 Civic VP with manual windows? I need to replace the door lock cylinders, door handles, etc.
Old Oct 20, 2021
Colin42's Avatar
Re: 2004 VP Inner Door Panel Removal
Remove the window crank, pop off the trim panel by the mirror, pop the little panel off that's behind the door handle, 2 screws there. Pull out the door handle and release the rod. Then one or 2 more screws in the armrest
Old Oct 20, 2021
gatrhumpy1's Avatar
So question: how do you remove the window crank? Do you just pull it out?
As far as the screws in the arm rest, they're hidden, and I don't want to pull something out that's not meant to be pulled out in order to access the screws. What do I need to pull up or off in order to access the screws in the armrest?
Thank you for your help!
Old Oct 20, 2021
remove the cap from the crank
Old Oct 20, 2021
gatrhumpy1's Avatar
For those that are curious!
Old Oct 20, 2021
gatrhumpy1's Avatar
Good lord! Removing that U-screw in the window crank handle was a freakin' damn pain in the ***!
Old Oct 21, 2021
wow, the honda crank is very different than my miata...
Old Oct 21, 2021
Colin42's Avatar
Isn't it just a clip? I use the rag trick or a pocket screwdriver
Old Oct 21, 2021
gatrhumpy1's Avatar
I could not fit a rag in there, and it's a U-ring. You have to push it up into the top of the handle in order to get a little screwdriver or something back there. Perhaps a paint can open could get it next time.
EarleD
Mar 31, 2014 07:35 PM
JoneYee
Dec 13, 2008 02:40 PM
fowl_18
Dec 31, 2006 06:56 PM
civictuner
35
Nov 10, 2004 12:39 AM
Diemos
Dec 29, 2002 02:37 PM
