Help ASAP
Old Dec 29, 2002
Diemos's Avatar
Diemos is an unknown quantity at this point
Help ASAP
So here I am, sony explods.. sitting in my garage with my friend. Supposedly, taking off our door panel is easy. Iv taken off 3 door panels before on 3 different cars, and I have to say this is by far, the hardest. How the HECK do you get this door panel off? Heres my problem, I am using that guide.. I am on step 7. Remove remaining clips by using the panel popper. Is the top of the door supposed to come off? And if IT does, HOW? I cant get it off..
Old Dec 29, 2002
Mystic3030's Avatar
Yup, i'm an A$$hole.
I'm assuming you've removed all the screws in the handle, and popped the little panel out of the A-Piller (where the tweet is on an EX) you should roll your window down to do this the easiest, and then you just lift the door panel up ....it should come off with a tug. On my EX the passenger door needed a much firmer tug than the drivers door.
On a side note, why did you buy XPlodes? [IMG]i/expressions/laugh2.gif[/IMG]
-Mystic
