- Transmission Grinding bad!!
- I'm stumped [solved]
- Transmission Lockup Intermittent 1997 Civic LX
- Transmission Issue
- Tran swap from CVT to something better
- Code P0730 Auto Honda Civic 99 LX
- Pops out of drive {deleting 'Got a problem any help appreciated" that is not helpful]
- d4 light blinking
- Clutch issue?
- 1997 LX Sedan Automatic Transmission Issues.
- Buying 96 Hatch
- 98 EX Shift Shaft Seal Removal - Breaking up in pieces
- Outer CV joint boot question
- Clutch disengages too deep
- Car making weird clunking
- transmission goes into neutral need helpp
- New clutch, No Start [solved]
- Sticky pedal
- P0720 Issues
- Stuck in D4 [solved]
- Transmission compatibility/clutch kit
- Ek hatch not going into gear
- Anyone know what happened??
- 2000 b20b swap civic fresh rebuild Ls tranny, popping out of 5th gear
- Transmission slip
- High rpm transmission problem
- P0730 98 auto civic
- New to automatics, pls help?
- Clutch not working
- Automatic non cvt hx trim
- 1997 Honda Civic, Shift Linkage problem.
- Need help
- p1768
- Quality Clutch Master Cylinder
- What trans do I need for my b16a swapped civic?
- Clutch fluid only bleeds when I push pedal
- Hard Shifting/Slamming when shifting from park to reverse and reverse to drive
- shifter play
- Code P0740
- PO700 and PO730
- B18 shifter bushing too small
- Dreaded code 715
- 98’ HX cvt transmission
- 96 Honda civic ex automatic stuck in 1st gear when cold
- Click sound when car shifts
- Something ain’t right
- Transmission Code
- Transmission Shift Solenoid.
- Tranny
- 1996 Honda civic (A/T) transmission temperature gauge install
- Vehicle Speed Sensor (Vss) sensor not available
- vss sensor swap
- Automatic Trans Codes in a Manual Swapped Car
- Clutch problem
- Honda Civic HX auto to manual swap
- Stuck on Parking
- 2000 sir trans stock clamping force??
- My civic wont go in gear except 3rd gear
- Sudden trans trouble
- Trans rattle.
- Car is running but not moving
- Clutch engagement point getting lower
- P1768 p1753
- 99 Civic 4th gear/overdrive isse
- Just purchased 1999 Civic w/85000 miles. Clutch chatter while downshifting into 2nd?
- Trans broke, need insight
- Stripped Bell Housing Bolt Holes
- Jigsaw puzzle
- B4RA Transmission Fluid
- Mini me swap trans codes
- 97 civic won't go in any gears
- wont shift out of 2nd gear
- Transmission grinding noise
- Key stuck in ignition/shifter moves without pressing brake or button or car being on
- Can't Push in Automatic Shift Lever Button
- gsr y80 trans pop out of 4th
- 99 Civic LX transmission delayed/hard shift
- Shift Lock Release Problem
- Who's good with trany symptoms?
- Won't shift into any gear after reinstallation of manual transmission
- 96 honda not shifting
- 98 Civic EX Coupe- 5 Speed Issue
- My Solution To Tranny Bad Imput Bearing
- Transmission problems P0700 & P0730
- pilot bearing
- Clutch Problems?
