shifter play
Old Oct 7, 2021
BlueEKCoupe98's Avatar
BlueEKCoupe98 is an unknown quantity at this point
shifter play
I had to rebuild the engine and do repairs on the manual transmission on my 98 civic ex coupe..I replaced all bushings to poly.. after I re installed everything I noticed I can wiggle the shifter side to side but only an inch either way.. will not engage or disengage gears. If you try, you snap your shifter. Running it does the same thing. I don't have the CV shafts in or MTF (synchro) put in, but that shouldn't make the transmission not shift into or out of gear. I'm stuck in 3rd and clutch seems to work fine. I have no clue what to do.
Old Oct 7, 2021
Re: Won't shift into any gear after reinstallation of manual transmission
there are tons of info above - have you tried them all?
If not, start testing what is already described here.
Old Oct 8, 2021
Loosen the bolt at the bottom of the shift lever. Shifter moves ok now?
Figure out what went wrong with your bushing install.
heliskelly
Apr 18, 2012 09:50 PM
Boilermaker1
Aug 21, 2002 02:07 AM
