Clutch fluid only bleeds when I push pedal
Old Oct 25, 2021
Devilriderman's Avatar
Devilriderman is an unknown quantity at this point
Hi,
I got a 97 Honda Civic DX 1.6 SOHC.
I had a clutch fluid leak, which seemed to be from the Slave Cylinder, so I replaced it. Went to bleed it, and opened the bleed screw and no fluid came out as it had done when I had bled the past(approx 5 times over the past 2 years!!!). Even now, if I open the screw, the fluid will only come out if I push down on the pedal, and the pedal is soft after quite a bit of bleeding.
I'm wondering if my clutch is on the way out?
Thanks in advance,
Ralph
Old Oct 27, 2021
Wankenstein's Avatar
Re: Clutch fluid only bleeds when I push pedal
Originally Posted by Devilriderman
Hi,
Thanks in advance,
Ralph
There's still air in it. Did you try gravity-feed bleeding it?
BobDobolina
Transmission
Aug 29, 2021 08:27 AM
Carlos24
Feb 6, 2018 08:40 PM
CaptainCrunch
Jan 8, 2015 09:53 AM
tandaman
Mar 19, 2009 07:24 PM
maiden4ever
Jul 13, 2004 12:46 PM
