Transmission slip
Hello everyone have a 98 Civic it slips between 2nd and 3rd and 3rd and 4th there is no engine lights on there is no dash lights on at all car runs beautiful no overheating no other problems only does it after it warms up. Would love some insights automatic transmission
Re: Transmission slip
Thanks appreciate the quick response any thoughts on the solenoids being plugged eating cleaned thought about giving that a shot and changing the fluid flushing yet not flushing if you know what I mean rinsing I guess. Tranny fluid looks brand new not burnt feels good smells good no metal shavings clean as a whistle I'm wondering if previous owner did a tranny flush which pushed everything Gunk up into the sensors. Never do a tranny flush unless you start out with a vehicle brand new and do regular flushes at the recommended mileage from new but if you have an older vehicle that you know nothing about or has never been flushed if you flush it you push up in your transmission that's an experience with that when I was much younger and was talked into a flush on my Chevy van Toyota training place they drove it around a bit did some colds with the gas pedal and driving it and fix it for me instantly not thinking that's going to be as easy with this
If the fluid is new ,that means they already changed it because of this problem. You can do the tests to see if any of the shift solenoids have weak clicks, but its likely the trans is on its way out. Same thing happened to me. Whatever you do dont buy a used trans.
you have a 7th gen
Plus there's no check engine light on there's no lights on the dash at all none of the gauges even flinch they're right on everything works on the car everything
No mine's 98 very well maintained car 220,000 MI but you couldn't tell by looking at it or driving it or the motor department the body's solid it was very well taken care of
