High rpm transmission problem
Old Feb 27, 2022
Stefic's Avatar
Stefic is an unknown quantity at this point
Hello, so i have a problem at high rpms (6-9k rpm) with changing gears. When i want to change gear at high rpms gearbox makes that sound "krrr". At low rpms it works great. B16A2 gearbox. Any help is welcome. Thanks
Old Feb 27, 2022
FRSam's Avatar
Click Here
Re: High rpm transmission problem
Is this with every gear or only low gears?
1-2 and 2-3 are fairly common because the gearing is low and it takes a lot of effort for the synchros to mesh, which is why they grind and eventually wear out.
If it’s in all gears, you probably need to change your fluid.
Old Feb 27, 2022
or you are not shifting correctly
or what maintenance have you done to it?
Old Feb 28, 2022
Stefic's Avatar
Its only happening 2-3 and 3-4, yea i thought oil could be the problem too so i changed it a weak ago, oil looked good, clean, no metal inside the oil but its still the same. Friend told me the clutch might be the problem but it feels fine to me idk.
If the gears are woren out what can i do about it?
Old Feb 28, 2022
direct question, direct answer
replace
it's expensive, mind you
Old Feb 28, 2022
especially for 2-3, try this:
  1. push out of 2nd
  2. release the lever
  3. let lever go back to center by itself
  4. push lever to 3rd
j3ffo
Jul 31, 2012 09:09 AM
return_2020
Aug 22, 2005 10:22 AM
BREEZE
Oct 11, 2003 12:53 AM
PESTLNC
Nov 10, 2002 01:10 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
