Sponsored by:
Sponsored by: CARiD
rpm limit
Old Oct 9, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
rpm limit
the more mods u put on your car does it change the redline of your car..???????????????
Old Oct 9, 2003
Project2k2's Avatar
errr no, that's only if u play around with your computer and reprogram the rev limiter.
Old Oct 9, 2003
BREEZE's Avatar
Yeah, i drive an EP
so the limit is 7.2
Old Oct 9, 2003
Project2k2's Avatar
I know our redlines are around 6.5k not sure exactly how much, but I dunno how high you can really take it, I have a DX=no tachometer.
Old Oct 9, 2003
nme3's Avatar
JDM wannabe
^^ same i hate that.
Old Oct 9, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
umm no mods except for a different ecu or reprogrammed ecu will change your redline
Old Oct 9, 2003
BREEZE's Avatar
Yeah, i drive an EP
well i have an ex and my redline is 7.2
Old Oct 10, 2003
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
on the tach. the bars turn red at 6800....but u can rev it to 7200
and at 7200 is fuel cut off point.
did that help u guys?
Old Oct 10, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
A word of advice, avoid hitting the fuel cutoff if at all possible...
Old Oct 10, 2003
Elite's Avatar
Elite is an unknown quantity at this point
it probably wont do anything considering the fact that there are lots of ecu's raising rev limiters on other egines d15, d16, i dont see why not d17
Old Oct 10, 2003
WannaBFast's Avatar
depends on what the engine is made out of... our engines most likely arent rated to go any hirer than 7500 sustained... so be cautious and not overrev, yes its possible to overrev your car, but im not going to tell you because i dont want to be responsible for breaking your engine
Old Oct 10, 2003
skarteez's Avatar
skarteez is an unknown quantity at this point
dont you need stronger valvesprings so the valves arent at a floating point when it revs too high and doesnt close all the way and risks colliding into a piston?
Old Oct 10, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
Does it depend if you have an LX or EX? I heard fuel cut on LX was 7K. Redline is the same....
Redline on a D16Z is 7200.
Old Oct 10, 2003
djmota's Avatar
D17's are different because of the ecu controlled ignition obd2's are a bitch.
NO ONE has been able to raise the rev limit yet with the stock ecu.
Old Oct 10, 2003
Project2k2's Avatar
hey I will take the blame....just be crusing at 80mph and drop it into second. that will do the job. (Warning do not try this)
Old Oct 11, 2003
cdmx's Avatar
Ive hit above 8k
Old Oct 11, 2003
cdmx's Avatar
or all the way to the top of the redline
annnnnd ill never do it again
Old Oct 11, 2003
Renamazazo's Avatar
is that cause your engine blew up?...
GolNat
Nov 27, 2018 03:32 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
bashea
Sep 15, 2015 04:59 AM
Juanb24
Sep 15, 2015 12:39 AM
99BoostedSi
Sep 7, 2015 04:49 PM
