Stuck in D4 [solved]
Old Aug 6, 2022
Maqcro's Avatar
Maqcro is an unknown quantity at this point
98 civic lx won’t start. Car thinks that it is in D4 but the actual shifter is in park. I unplugged the range sensor on the side of the shifter. How can I fix it so it works again?
Old Aug 6, 2022
Colin42's Avatar
re: Stuck in D4 [solved]
Tried in neutral? Try another range switch from the junkyard?
Old Aug 7, 2022
Maqcro's Avatar
Yes tried in all positions no start at all. Picked up another switch from junkyard. The actual plastic range slider broke where the metal pin slides when you move shifter.
I guess electronically the car thought it was still in d4 but mechanically was in park.
replacement part worked good and fixed the issue.
Old Aug 7, 2022
Colin42's Avatar
Re: Stuck in D4 [solved]
Glad you got it figured out
Millsy088
Suspension
19
Dec 30, 2021 02:08 PM
tolgaek
Dec 19, 2014 07:41 PM
redbug2
Transmission
19
Jul 3, 2014 08:51 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
hardboil
Wheels and Tires
Feb 9, 2009 11:13 AM
