Notices
Wheels and Tires Post your wheel and tire related questions here.
Sponsored by:
Sponsored by:
05lx,front rotors phillips screws, stuck stuck
Old 01-07-2009
hardboil is an unknown quantity at this point
Post 05lx,front rotors phillips screws, stuck stuck
hiya
Im just trying to take out the Front HUB to replace the bearing, Im stuck with these phillips head screws, they are stuck in there and afraid the screw head is almost wasted. I put some wd40 on the outside just in case and try with a screwdriver first and then a dewalt drill, the drill doest move it and the heads are almost gone now.
I need tips on this, i have the wheel off and brakes and no car to move, I'm riding a bicycle heh.
hardboil is offline
Old 01-07-2009
popee will become famous soon enough
Re: 05lx,front rotors phillips screws, stuck stuck
I think you need a impact screwdriver.. to take off the screw on the rotors gotta bang the top of the screwdriver while turning the screwdriver
popee is offline
Old 01-07-2009
DDragon7's Avatar
If the impact screw driver doenst work, you'll need to drill them out. And dont put them back in, you dont need it, they only hold the rotors in place at the manufacturing plant.
DDragon7 is offline
Old 01-07-2009
thanks both of you, will try tomorrow.
I was just thinking i will also have problem taking off the spindle lock nut, it have a lock dent on it and im not sure which tool to use for this
hardboil is offline
Old 01-07-2009
04 Honda Civic's Avatar
Use the impact driver mentioned above if that dont work heat them ****ers up and try it that way when they are hot. I had a hard time taking em out to change my rotors. As for that huge lock nut you can use a small head screw driver to pry it up as well as putting it back on.
04 Honda Civic is offline
Old 01-08-2009
they have extraction bits at sears that may work too if its stripped, but its gonna have to be an impact. theres just too tight to get out by hand.
gearbox is offline
Old 01-08-2009
WoW no go. I broke the phillips bits and the drill even smoke and no luck, the screws are solder into the rotors. I tried hitting it with a hammer and screwdriver and is like nothing happens. I dont know what else to do with this maybe theres some other special tools?
Yeah impact, i need to look for a impact drill? no sure which one is the correct one for this
hardboil is offline
Old 01-08-2009
TRIZ's Avatar
Its an impact screwdriver. You wack the back of it with a hammer and the screwdirver does a forceful 1/4 turn which will break those screws out of their rust. Heating them up wont do **** for you. Its all the heating and cooling from your breaks that got them suck in place like they are. And they arent soldered in there... you just need to pick up the special tool... an impact screwdriver.... like everyone has been telling you!!
TRIZ is offline
Old 01-09-2009
Where i can find these impact screwdrivers at?
hardboil is offline
Old 01-09-2009
Love me some nice, long-lasting vics!
jgcentury's Avatar
jgcentury will become famous soon enoughjgcentury will become famous soon enough
This is your answer right here. Get a drill bit and just drill straight through the middle of them bastards till they break. I had to do the same thing cause mine stripped out. Like DDragon said, they are unnecessary, just there to keep them from falling off on the assembly line workers toes or heads. If your drill bits or drill can't make it through these tiny *** screws, you need to buy new tools.
jgcentury is offline
Old 01-09-2009
you can go to go your local auto part store they are some 20-100
depending if you want to cheap stuff or the good stuff
hardboil;4377067]Where i can find these impact screwdrivers at?
popee is offline
Old 01-09-2009
jgcentury's Avatar
Did you get them out yet?
Old 01-09-2009
rednek is an unknown quantity at this point
Agreed. I tried the impact screw driver but they weren't havin any of that! $40 for some good drill bits and some time later there was nothing left of the screws, and off came the rotors.
rednek is offline
Old 02-09-2009
Problem solved, i got everything out the other day with the same drill. thanks all for helping
hardboil is offline
GolNat
Suspension
08-16-2015 08:18 PM
bsmiley
7th Generation Civic
04-27-2015 01:27 PM
chgofirefighter
Vehicles for Sale/Wanted
04-18-2015 08:08 PM
C2i0v0i1C
11-14-2001 10:46 PM
Quick Reply: 05lx,front rotors phillips screws, stuck stuck
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
