Automatic Trans Codes in a Manual Swapped Car
Old Jul 21, 2020
Brock Webb's Avatar
Brock Webb is an unknown quantity at this point
Hello all!
I have a 2000 Civic ex coupe that has been manual swapped at some point in its life and I have a couple codes stored in the computer that I don’t know how to fix. The codes are P1768 (torque converter clutch solenoid valve b circuit) and P1706 (neutral safety switch).
Given I no longer have an auto trans, is there a way to fool the computer into thinking these parts are in working order?
Old Jul 21, 2020
Colin42's Avatar
Re: Automatic Trans Codes in a Manual Swapped Car
Put in a manual ecu
Old Jul 21, 2020
Brock Webb's Avatar
Originally Posted by Colin42
Put in a manual ecu
Right but is there not a way to splice wires and add say a resistor to it so it gets whatever signal it’s needing? I don’t particularly want to have spend money on it if I don’t have to.
Old Jul 21, 2020
FRSam's Avatar
Click Here
Then just drive it.
For the sake of maybe $100, just get one. You open yourself up to a lot more potential issues trying to fool ECU's like that. You can get one from the junkyard for probably half that. They're roughly $40 CAD where I am. Probably even cheaper on classifieds.
Old Jul 22, 2020
mac25's Avatar
Dr Krieger of Modification
Its possible but not worth the time, effort or money. Manual ecu would be cheaper.
youd probably have to buy a digital signal simulator, and know the signals given to the ecu, then create a map of the expected signal regarding, gear, rpm and load. Similar to creating a custom map for tuning.
robmobabri
Aug 15, 2018 01:55 PM
P...
Mar 24, 2018 12:26 AM
jjaayy
Feb 26, 2018 08:58 PM
Champ6
Dec 11, 2012 11:38 AM
HCMCVTEC
May 21, 2012 11:00 PM
