New clutch, No Start [solved]
Old Sep 2, 2022
Wrathwisp's Avatar
Wrathwisp is an unknown quantity at this point
I've went & replaced the clutch in my 97 Civic LX. Got everything bolted up & plugged in. Went to try & start it up but it doesn't seem like its getting any fire; it turns over & is getting fuel though. I don't have any check engine light so that parts kinda stumping me.
Also want to add that I forgot to unbolt the battery at the time, rookie mistake I know. Maybe a blown fuse?
Old Sep 2, 2022
GolNat's Avatar
Prelude Owner
re: New clutch, No Start [solved]
Could be a fuse or a ground wire that you forgot. Are all the starter connections tight?
Old Sep 2, 2022
did you mess around the clutch switch?
Old Sep 2, 2022
Wrathwisp's Avatar
I'm thinking it might be a fuse. I'm about 99% sure that everything is grounded properly, will have to check in the morning. As for the starter connections I know those are all tight.
Old Sep 2, 2022
Wrathwisp's Avatar
Do you mean the clutch safety switch inside the car? If so, the only issue I've ever had with that is the plastic nip that commonly breaks. I just did the trick where you stick a coin in its place.
Old Sep 3, 2022
just checking since it could be the cause
yes, the safety switch
Old Sep 3, 2022
Wrathwisp's Avatar
Okay, ended up getting the car started! Turns out we just flooded the hell out of it. So basically, user error. Got it in reverse & out into the road went to throw it in to gear. . . and nothing. But that turned out to be the passenger CV popping out about 2 inches.
fchafey
Transmission
Nov 1, 2021 04:08 PM
thesupersoap33
Transmission
Oct 10, 2021 07:24 PM
F22C4me
Air Conditioning
Oct 8, 2021 01:41 PM
ernest64xp
Electrical
Mar 1, 2021 02:53 PM
Sparty
Transmission
Jan 22, 2002 03:41 PM
