Clutch not working
Old Feb 8, 2022
gmd25m's Avatar
97 Civic HX Manual
gmd25m is an unknown quantity at this point
Clutch not working
I am having the same problem. I have a 1997 Civic HX, I left at my mother's when I moved in the late Fall of 2019. I couldn't travel back to my mothers to get it because the pandemic hit shortly after I moved and didn't travel. Fast forward to November 2021, first time back to visit my mother and start the car for the first time in nearly 2 years. I am able to start and drive the civic about 10 miles until I come to a parking lot. At that point I park and when I start the engine the clutch won't go into gear. I can put the clutch in neutral with the engine off but not with the engine on. There was a full amount of fluid in the clutch fluid reservoir.
I am back trying to fix the car. I replaced the whole external clutch hydraulic system - hose, pipes, CMC and CSC. I thought I bled it well and proper, with the slave moving with the pedal depressed. Despite all this, no clutch disengagement.
I really want this problem to be the CMC, CSC and a bleeding issue, I am trying to NOT have to drop the tranny to fix something else.
Given the above, my questions are:
1) With the slave cylinder removed, there is quite a bit of "loose rattling" of the clutch fork. Is this normal>
2) How much slave + clutch fork movement is to be expected with a properly bled system ?
I took some videos of the movement and put it on youtube. Can you tell me if the travel of the CSC with the clutch fork is enough ? Is the clutch fork "rattle" with the slave off something that is expected ?
Here is the Clutch Slave seemingly moving the clutch fork; the clutch still doesn't disengage. Is this not enough movement?
Here is the movement of the clutch fork without the slave cylinder, should there be this much rattle with no slave cylinder?
Old Feb 9, 2022
Re: Clutch not working
most likely your clutch plate collapsed.
Old Feb 9, 2022
BrotatoChip's Avatar
Super Moderator
Sure looks like enough movement at the slave cylinder to me. Some rattling at the fork is normal when the slave isn't installed. I don't think that looks excessive.
Old Feb 9, 2022
gmd25m's Avatar
97 Civic HX Manual
Thanks for the reply and that type of issue (where I have to drop the tranny) is exactly what I was hoping to avoid. Can you tell me:
1) Do you say it is most likely the clutch plate because the slave and fork movement look ok ?
2) If it is as you say, clutch plate done, I would assume that a "typical" clutch job with new pilot bearing, polishing the flywheel, new fiction disk pressure plate and throwout bearing would be the remedy ?
Thanks again for your input .
Old Feb 12, 2022
Colin42's Avatar
Should be the fix.
not too bad to do in the driveway
shahar
Transmission
Jul 13, 2020 08:48 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
peachrules
Jan 10, 2012 09:58 AM
chopper202
Oct 6, 2009 03:30 PM
XipeTotec
Dec 30, 2007 08:52 PM
