PDA
View Full Version : Brakes
  1. 2014 EX Brake Pad Brands
  2. Weird Spongey brake problem. 2011 civic
  3. ABS module, stuffed, and super expensive
  4. 2008 EX: how to compress caliper piston?
  5. Handbrake conundrum
  6. Can I drive with only bleeding 1 drum?
  7. encouter different kind of ceramic pad, what to choose?
  8. Honda civic ima code 24-01 fault
  9. 2009 Civic SI Permanent ABS DTC (56-1) (61-1) (83-19) (86-1)
  10. 1st Brake Job
  11. ABS sensor screw
  12. Master cylinder leaking
  13. Caliper/Brake tightness
  14. Break Bleeding Issues
  15. Issues replacing Brakes 2006 civic hybrid
  16. 2007 Civic Soft Brakes After Numerous Bleeds [solved]
  17. 84-11 VSA Sensor Neutral Position Memorization Incomplete
  18. Rattling sound when braking [ATTACHED VIDEO]
  19. Brake drum max diameter
  20. ABS issue
  21. Brake line heat shield question.
  22. Driver's Caliper piston dust boot seal, bleed screw cap, and cv axle boot are torn.
  23. 2007 Honda Civic LX: Knocking sound from rear drum when braking
  24. 06 Civic MT rolls back when on incline with emergency brake engaged
  25. Brake Fluid - Brand and Kind
  26. Hot Wheels...
  27. Low Break Fluid warning (when it's not low)
  28. Front disk brake guide pins location [solved]
  29. 2007 civic caliper bolts
  30. Civic Handbrake adjustment [solved]
  31. 2007 Honda Civic LX temporary had brake line open need to bleed now?
  32. Brake fluid leak
  33. Brake shoes...swapping leading with trailing
  34. Stock brake SHOE material
  35. Clicking sound from brakes
  36. 2012 Brake mismatch
  37. Brake System amber light
  38. ABS control unit rebuild suggestion
  39. Genuine Honda parts vs aftermarket
  40. Front wheels don't spin freely?
  41. Extremely uneven brake rotor/pad wear
  42. 07 civic LX coupe, rear wheel cylinder leaks
  43. Grinding Sound.
  44. Brakes keep locking up [solved]
  45. Brake Line Replacement [solved]
  46. VSA module, brake master cylinder replacement - anyone had problems?
  47. A Click sound when brake pressed
  48. Brake pedal soft after front caliper replacement
  49. Very crusty rear brakes
  50. Services
  51. 09 Civic - Faint Grinding/Scraping Under Braking
  52. Shop said ABS light would go off in a week
  53. MAjor Brake Problems. Suggested upgrades?
  54. hot brakes cant be normal?
  55. 2013 Brake drum bolt size???? Not M8x1.25
  56. 2010 Civic LX front brakes
  57. Rear disc brake problem
  58. brake booster
  59. 2014 Honda Civic EX crunching noise
  60. 2014 EX Rear Shoes
  61. thump noise when stopped
  62. ABS sensor replacements won't work
  63. Rubbing sound
  64. Do I need new brake pads? (Photo attached)
  65. New CV axles, calipers, rotors, pads
  66. What brand calipers?
  67. 2013 Civic LX what is thickness of new brake pads & tires
  68. Premature brake pad wear?
  69. Brake Caliper Piston Won't Retract
  70. Stumped. Brake issue
  71. 2013 LX rear brake shoes replacement
  72. part numbers
  73. Help!!! brakes sink to the floor honda civic 2012 LX coupe
  74. Noise
  75. Dixing brake pedal switch
  76. Valvoline dot4 brake fluid civic 2010 lxs
  77. 2010 LXS installed new front brakes today!
  78. Front brake pad replacement and bleeding
  79. 2007 Honda Civic LX: Front caliper guide pin head size + bleeder head size, nipple sz
  80. 2013 civic sedan what size hose will fit the bleeder nipple?
  81. My 09 si
  82. Brakes aren’t that sharp.
  83. Time for brake service?
  84. 2014 Civic EX Rear Brakes
  85. Ceramic brakes grinding????
  86. New Pad Fit Issue
  87. How much / tree brake fluid
  88. 2010 EX sedan brake replacement question...
  89. Need some advice about brake calipers
  90. 2006 civic but general brake bleeding question
  91. 2010 civic premature front brake wear 3 times
  92. Thoughts on installing brakes myself
  93. Parking Brake Adjustment
  94. Rear caliper problem
  95. Using spray bottle to bleed brakes
  96. dust shield replacement
  97. Front brake smell issue
  98. rear wheel gets stuck randomly (video)
  99. brakes 08 civic ex
  100. 2007 honda civic hybrid abs problem
  101. Loud Mechanical Bangs After Braking Hard
  102. 06 Civic Rear Brake Shoes... ^%)@_@#$R!
  103. Class Action Suit--> brake pad wear
  104. Abs and brake system light on?
  105. abs code 61-01
  106. Honda Civic 2010 LX Sedan
  107. 2006 Civic - When will break pads need replacing?
