Brakes Post information/questions/Issues about Brakes here.
Hot Wheels...
Old Jun 7, 2023
shadow4's Avatar
shadow4 is an unknown quantity at this point
Hot Wheels...
Hey Friends, I hope I posted this in the right area; sorry if I didn't.
I'm looking for a Civic for my Daughter. I've test driven a few civics, and the last one I test-drove was a 2015 LX model with hubcaps. When I got back from a roughly 12-mile test drive, the wheels under the hubcaps were very hot, like too hot to keep your finger there for long. The front wheels were the hottest, and they would burn your fingers if you touched them for a few seconds. The back wheels were hot, but not "burn your hand hot" like the front wheels.
First, is this normal? Second, if not, is this an easy fix? The car was in great shape other than that, and I saw the service records.
Thanks!
Old Jun 7, 2023
Re: Hot Wheels...
did the brakes work?
Old Jun 7, 2023
shadow4's Avatar
Re: Hot Wheels...
The brakes worked fine. I"ve just never had wheels heat up on any vehicle I've owned this much. I drove my Tacoma on a 40-mile trip today and the wheels were no more than 100 degrees, and this is in FL.
When test driving the Civic, I didn't do a lot of braking. Maybe a 7-8 stoplights at the most, and the rest was highway.
Old Jun 7, 2023
Re: Hot Wheels...
the first thing to suspect is sticking brakes in that case.
meaning might be easy work to solve (or complicated if it in the end involved changing the calipers.) not expensive, though.
Take somebody mechanically inclined to look at the car next time you go there
Old Jun 7, 2023
shadow4's Avatar
Re: Hot Wheels...
Thank you! I'm pretty mechanically inclined, and I suspected the brakes or the bearings, but I wanted to see if this was common (or even expected). I would have them fix it before purchasing the car. I haven't started negotiating the price yet and didn't bring up the hot wheels to them yet.
Thanks again!
Old Jun 7, 2023
Re: Hot Wheels...
not common on older car makers, I would think most of renowed makers would not make that type of mistakes...
other than some, of course...
the prius throttle was a new electric pedal, GM ignition with heavy keychains is not so easy to predict, for example. But stick brakes, they would not make that mistake (hopefully)
A Tesla... or some of the new entrants, on the other hand....
Old Jun 8, 2023
Colin42's Avatar
Re: Hot Wheels...
Calipers might be sticky, weird that all 4 would be super hot inless you were doing some heavy braking. If the car had been sitting for a bit and the rotors were rusty then maybe they would be a little hotter than normal. If your going to pursue the car i would get the dealer to a 4 wheel brake service at a minimum.
Old Jun 8, 2023
BrotatoChip's Avatar
Super Moderator
Re: Hot Wheels...
Wouldn't the steel wheels feel hotter than regular aluminum ones? Maybe I'm mistaken.
Old Jun 8, 2023
Colin42's Avatar
Re: Hot Wheels...
Aluminum is a much better heat sink than steel
CuRiOuSfIsH
Jun 7, 2005 04:24 PM
lostid
Mar 13, 2005 11:34 PM
winnerpl
Aug 2, 2004 06:26 PM
bytemare
22
Jul 31, 2004 10:52 AM
scottwillcocks
Jul 3, 2004 06:51 PM
