Brakes Post information/questions/Issues about Brakes here.
Brake Fluid - Brand and Kind
Old Jun 8, 2023
mreisusa's Avatar
mreisusa is an unknown quantity at this point
I am doing my brakes (Civic 2006 EX Coupe) for the first time. I am broke, and tired to waste $ with mechanics that seems not to do something that good, or care. Anyway, on my search for ways and answers, I found that it seems that the DOT 5 in not at all recommended for the car (boiling point), only the DOT3 ( originally) or DOT4. Since that was my daughters car, I do not think that the mechanics (even at Honda) have ever flushed the brake fluid, and since I am changing the rotors and pads, I checked and saw that the fluid is also looking pretty bad, and I am changing/flushing it. But which one to use: Honda 08798-9008, Adam's x Recochem OEM Blue(for Asian Vehics), ATE Superblue...? As always any help will be highly appreciated?
Old Jun 8, 2023
Re: Brake Fluid - Brand and Kind
regular DOT3/4 sold in parts stores.
hondas do not need special brake fluids.
Other fluids might require OEM fluids, but not brakes or coolant. Engine oil just need to meet oil weight. I think clutch also is OK
but transmission, power steering need specific OEM fluids
Old Jun 8, 2023
FRSam's Avatar
Click Here
I used the generic DOT4 I had in my garage when I did the brakes on my TSX a few years ago. For this application, you don't need anything special.
Old Jun 8, 2023
mreisusa's Avatar
Thanks, I red something about the seals if using other fluids, but saw that mostly people were using the ATE Superblue or some say that the OEM blue for Asian cars would do it. I almost going to Prestone and calling g it a day.
PS.: One thing that i also saw while researching about it was that, even without use, old break fluids got bad on the bottles, after been open for too long (maybe for not been closed right, or left open for too long)
Old Jun 8, 2023
brake fluids take on humidity from air, you don't want water in a fluid that will heat (a lot)
well known that brake fluids suck moisture in (I knew from back in the 90's)
Old Jun 8, 2023
Colin42's Avatar
Brake fluid should not be used if the container was opened more than 6 months ago, sooner if you're in a super humid area. Never heard of blue brake fluid. Just buy the normal cheap dot 3/4 stuff
prr
Mar 20, 2018 03:47 PM
Saratoga
Jan 11, 2012 05:14 PM
newbie101
Wheels and Tires
Jan 23, 2010 11:34 PM
KINGCHILE
May 25, 2006 11:58 AM
streetglower
27
Jun 18, 2004 10:06 AM
