Brake Fluid Capacity
I have a 2009 Civic. I will be changing the brake fluid. Does anyone know what the capacity is? Is there any difference between the Honda brake fluid and the regular DOT 3 or 4?
Re: Brake Fluid Capacity
You want to bleed ur brakes every year or 12,000 miles
And you want to flush ur system with new fluid every 2-3 years
You do NOT want to wait till the fluid is low
Usually when it says "dot3 and dot4 compatible" it means the brake fluid is a dot4 standard and since the dot4 standard is higher than dot3, you can use this brakefluid for applications that use dot3 fluid
i waited 3.5 yrs cause i didnt have the money to get a flush and the brakes changed separately, and there were all sorts of floaty chunks in the reservoir and fluid was dark. i sucked the chunks out before taking it in so it wouldnt get stuck in the lines. this was in a dry desert climate with a pretty new cap. i dont think i would even wait 3 yrs anymore unless i had to. 2 yrs is a good time to get use from the fluid but not long enough to degrade the fluid. honda does recommend 3 yrs (not mileage dependent) for a flush of the brake fluid.
True that Honda recommends every 2 years but that's just the average. If u live in hotter or colder weather, the maintenance intervals will come much sooner.*
And once air or water gets into ur brake lines (especially in the caliper area) the wet/dry boiling point really suffers....especially under heavy braking, ur brakes get HOT
Not only does braking suffer if you dont change fluid, your brake pistons can sieze and many times they cant be rebuilt and need to be changed all together.
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
If it has Dot 3 in it and your not replacing it then i would use any dot 3..you can mix brands just not grades..
im most parts store, they only offer a "dot3/dot4"
most of them are a true DOT4 fluid but it is backward compatible. so if the bottle says DOT4, it is safe to use on a car that has been running DOT3 (but at that point you should flush ur system)
the only brake fluid u DONT WANT TO MIX is a DOT 3/4/5.1 with a DOT5.
DOT 5 brake fluid is a silicone base fluid and cannot be mixed with DOT3/4/5.1
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Causemo
Jul 5, 2015 06:42 AM
