Brake fluid and pad???
Old May 25, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
I get my rotoras put on today, and i wanted to know what fluid i should put in. Ive heard alot about motul, is this a good fluid? what are the other options? Also, what brake pads are good and dont produce too much brake dust?
Old May 25, 2006
Da1lyDr1ver's Avatar
motul is very good brake fluid. however, it tends to pick up dirt very quickly so it needs to be changed very frequently (exp: after a day at the track). valvoline synthetic is supposed to be good as well (a step up from OEM), and does not require you to change the fluid as often (i'm running this in my car).
Jul 12, 2015 11:54 AM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
