Brakes Post information/questions/Issues about Brakes here.
Can I drive with only bleeding 1 drum?
Old Oct 18, 2024
alon's Avatar
alon is an unknown quantity at this point
Hi,
I am new to this site, but I get a lot of good info from here and thought maybe people can help with this one.
I have a 2007 civic and I changed the brake fluid. I bled all the brakes except 1 drum in the back since the bleeder bolt is seized. How bad is to drive like that? The brakes feel fine, actually pretty good, way better than before. So I am guessing everything is good?
Thanks in advance!!
Old Oct 18, 2024
FRSam's Avatar
Click Here
Re: Can I drive with only bleeding 1 drum?
I’d fix it ASAP. Brake fluid is corrosive as hell, not to mention you’ll lose your brakes once you’re down enough fluid.
Old Oct 19, 2024
Colin42's Avatar
If you cant get the bleeder, try loosening the hose and bleed there
Johnsoto11226
Apr 27, 2016 09:43 PM
BenT07891
Aug 2, 2011 10:40 AM
adh2002
Wheels and Tires
Oct 21, 2009 01:50 PM
mk32382
Dec 1, 2003 10:18 AM
ZSKCivic01
Mar 22, 2003 08:39 PM
