Brakes Post information/questions/Issues about Brakes here.
dust shield replacement
Old Mar 31, 2019
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
been hearing some faint noise from my front side turns out my dust shield has rotet away and is atached loosely on. do i have to take off the wheel hub or can i just follow this guys directions.??
Old Mar 31, 2019
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Re: dust shield replacement
Great Video.! That's Actually a great idea to do but i dont think it will work on star type screws that can easily be stripped from rust Why Honda didnt use bolts to hold it in place? there counting there pennies and Nickels On the assembly line is my answere to that, to properly replace it wheel bearing has to come off. or If the piece aint too big You might be able to
Just Cut the loose part off using some kind of Rotary tool with a small wheell on the end. its spring right now where we are. i dont think it will harm anything for the time being however come winter months definatley get'r Fixed.
Old Mar 31, 2019
the loose portion is less than half of all its shield size together, so.. for now takeing off wheell bearing is too much work to do come warmer hot days im gonna try cutting it. Thanks
Old Apr 1, 2019
please start posting in the right sections.
We created new places to best sort the issues
8th gen root forums are not the best place.
JVcivic
Oct 26, 2017 04:10 PM
DAC
Dec 19, 2016 08:31 PM
califcamper
Suspension
Apr 11, 2016 03:43 PM
mikey1
Apr 21, 2013 12:09 PM
xDCx
Aug 1, 2005 10:36 PM
