Brakes Post information/questions/Issues about Brakes here.
What brand calipers?
Old Oct 22, 2020
joenobodyyet's Avatar
joenobodyyet is an unknown quantity at this point
I have a 2008 Honda Civic LX automatic transmission sedan (102,000 miles). What brand calipers should I get? Any brands to avoid? Is it ok to get remanufactured calipers? Does coated or uncoated matter if I live in Philadelphia, PA? I had very premature brake pad wear on both sides. I looked at the caliper and the rubber dust cover seal on the piston is torn on both. On one of the calipers, the rubber boots on the slide guide pins weren't attached to the caliper, just to the pin. The pins were all gunked up although I put fresh sil glyde in there a year ago. Anyway, I don't feel like rebuilding the calipers, and I don't think they're that expensive, so I was just going to get new ones. Do new calipers usually come with everything including guide pins and the rubber boots? I've seen some online that say they don't include the bracket. I guess I can just use my original bracket? Thanks
Old Oct 23, 2020
BrotatoChip's Avatar
Super Moderator
Re: What brand calipers?
I would recommend a coated set to avoid rust in the future. Most sets do come with the caliper, bracket, and all hardware. Make sure you get one of these sets.
Old Oct 23, 2020
GolNat's Avatar
Prelude Owner
I’d go used OEM set. Coated is best especially around Philly.
joenobodyyet
Brakes
Aug 24, 2020 03:54 PM
TRIZ
Brakes DIY
Jul 31, 2015 09:27 AM
compmaker1
Oct 15, 2012 11:52 PM
Revmaster
Jan 9, 2005 12:50 AM
streetglower
Jul 17, 2004 02:41 PM
