Brakes Post information/questions/Issues about Brakes here.
Brake System amber light
Old Sep 27, 2022
Maineaussie's Avatar
Maineaussie is an unknown quantity at this point
2009 Hybrid, checked it all, all new brakes, car drives and stops great, just can’t get the Brake System light to go out, and because of it AutoStop doesn’t work. Any ideas on how to reset?? I’ve disconnected battery (it’s new), bled all brakes, fluid full, #4 fuse good, I’m at a loss.
Old Sep 28, 2022
BrotatoChip's Avatar
Super Moderator
Re: Brake System amber light
Is the parking brake released? Maybe the switch is bad.
Old Sep 28, 2022
Parking brake works perfect….no issues….I just can’t figure out what it could possibly be
Old Sep 28, 2022
you missed this part
Old Sep 28, 2022
What switch?? It’s not the red Brake light that is on…it’s the yellow Brake System light…
Old Sep 28, 2022
not familiar with that gen cars or hybrids, but parking brake lever that are mechanically activated usually have an electrical switch that signals if the brake is activated or not...
that switch can be damaged or dislocated or wires could have been pinched, etc and it could have been the culprit for malfunctions if it is not sending the signal properly
electronical/electrical parking brake systems would not have the switch, but your car should have an cable activated parking brake, thus mechanically activated. Your car do have a parking brake lever, non?
Old Sep 29, 2022
Super Moderator
I think that indicates there is an ABS fault. Take it to an auto parts store and get the faults read.
Old Sep 29, 2022
Yes I thought that too…put a code reader on it and it reads no faults for ABS….
Old Sep 30, 2022
Could faulty master cylinder put that light on???
Old Sep 30, 2022
Colin42's Avatar
Should be braking weird if the master is bad
Old Sep 30, 2022
It’s not braking right….it starts to but the pedal can go to the floor…it almost feels like internal leaking going on…that’s why I suspect the master cylinder…I’ve done everything else I can think of. You would think that the “brake system” light would at least throw a code…nothing.
Old Sep 30, 2022
Colin42's Avatar
And you didn't think to mention that in any of your other posts!? Your first post says "drives and stops great"
Old Sep 30, 2022
As of yesterday it was….then after really working the brake pedal a few times it started feeling more and more mushy….but otherwise it was stopping fine but still didn’t “feel” right…..
Old Sep 30, 2022
Just trying to figure it out is all…no worries….thanks for reply’s 👍
Old Sep 30, 2022
Colin42's Avatar
Well the master is probably bad
Old Oct 1, 2022
Lol ok so everything is disconnected and MC is loose but just won’t come out…feels like something is still connected somewhere….took pin out of brake pedal….is there something else I’m missing?? It moves out maybe 1/4 inch or so and then something stops it….anybody?????!!!! Thanks…
Old Oct 1, 2022
Hybrid must be totally different than regular civics….just wondering I’f I need to remove the brake pedal and pull everything out….just can’t find anything anywhere about it…..frustrating for sure
NatandAndy1031
Brakes
16
Jan 31, 2024 12:42 PM
Low_Lupe
Aug 17, 2015 10:57 AM
RFG1022
Dec 5, 2014 09:23 PM
taehoshi
Dec 7, 2005 12:32 AM
SevenCyrus
May 27, 2005 05:45 AM
