Stumped. Brake issue
Hello, new here and need help. I have a 2007 Civic EX. Car was sitting about a year. Had to replace all brake pads, rear calipers and rotors. Trying to bleed all brakes and getting no fluid on right side. Bleeders are clear,. Never seen a vehicle that was split left to right not front and back. Is that how Honda is? I can't figure out why no fluid on right side.
Re: Stumped. Brake issue
Do you get fluid if you remove the bleeder completely? What if you crack the fitting where the line hits the caliper? Just work your way back until you find where the blockage is
I opened the line back where it connects on wheel well from metal to rubber and no fluid. i assume there is a blockage somewhere but its not allowing fluid to front or rear and i don't know where to check. Master cylinder should split front and rear not left and right correct? has me confused.
John123Drury
Mar 25, 2017 11:28 AM
streetglower
27
Jun 18, 2004 10:06 AM
