brake question
Old Apr 10, 2009
CivicJR22's Avatar
CivicJR22 is an unknown quantity at this point
brake question
i changed the front brake pads only .. do I have to bleed all four wheels or just the fronts???
Old Apr 10, 2009
04 Honda Civic's Avatar
Re: brake question
You dont need to bleed the brakes.
Old Apr 11, 2009
Shifty's Avatar
Re: brake question
no need to bleed the brakes when changing only pads. Only in times when you open the system to air (i.e. when changing brake lines) do you need to bleed.
I would just check the brake fluid level just in case some drained out when you pushed the caliper piston back when you did the pads.
Old Apr 11, 2009
sl33pyriceboi's Avatar
Re: brake question
no need to bleed all 4, but it is HIGLY recomended. im sure its been a while since you've bleeded ur brake fluid and it'll be a great way to have a fresh start with new pads and NO AIR BUBBLES IN UR BRAKE LINES!
Old Apr 11, 2009
Re: brake question
If anything the level rised
Old Apr 11, 2009
Re: brake question
if its been more than 3 yrs, time to flush it.
Old Apr 11, 2009
Shifty's Avatar
Re: brake question
Yeah i know, the reason i said to refill is sometimes pple let the pads go too low and when they see the brake master cylinder with the fluid low, they add more. So when they push the piston back to put the newer (thicker) pad, brake fluid will now overflow....make sense or did i lose you? again
Old Apr 22, 2009
Re: brake question
I get it, I have done that before with the older car I used to have
7thgensurvivor
38
Aug 29, 2015 11:50 AM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
