Brakes Post information/questions/Issues about Brakes here.
ABS sensor screw
Old Aug 12, 2024
Mbaint1013's Avatar
Mbaint1013 is an unknown quantity at this point
ABS sensor screw
I recently replaced both of the wheel(/hub?) assembly’s on my 06 civic. While doing this, the ABS sensor broke off in the casing on both sides and the old screws are trash. So I bought new sensors for each side but they didn’t come with the screws to secure the sensor to the case. I’ve checked multiple sources but can only find a vender that will charge $8 for each screw or is 2weeks for delivery. Trying to find the exact screw but not from a dealer. Is there anyone that knows how to find or knows off the top of their head the exact dimensions for the screw I’m looking for? It says m8x20 but idk the length or pitch to be sure it’s correct
Old Aug 12, 2024
Re: ABS sensor screw
not modification, rather a mechanical issue, moved to correct section.
Modified section means an upgrade from stock parts
Old Aug 13, 2024
BrotatoChip's Avatar
Super Moderator
This bolt? It's an M6x1.0, 16mm long according to the parts diagram. Part number is 95701-06016-08 if you want OEM. Basically any hardware store will have an M6x1.0 bolt you can cut shorter if needed.
Rtelino
Brakes
Jun 8, 2022 06:33 PM
xavier2011
Brakes
Jan 21, 2021 08:56 PM
Bricktop ivi
Mar 19, 2014 12:05 AM
Victor520
Jan 22, 2013 03:56 AM
jsiu85
Jan 12, 2008 12:56 AM
