PDA
View Full Version : SOHC D17Ax non-VTEC - VTEC Engine Swaps
  1. d17a1 - d17a1
  2. D17a1 motor swapped to d17a1 original car. (Non vtec to car that had vtec )
  3. OKAY!>Engine swap
  4. D17a1 in vtec car help!!
  5. D17a1 swap too d17a2
  6. P1259 on d17a1 engine?
  7. Engine swap
  8. Engine swap dx to ex
  9. D17A1 swap into an EX that had a VTEC D17A2?
  10. non-VTEC engine to VTEC car
  11. 1.7l to 1.3l swap
  12. 01 to 05 engine and trans swap [closed]
  13. Vtec-ecu questions evap
  14. D17a swap
  15. 05 Civic VP swap cost
  16. Help 04 vtec swap
  17. 2003 civic Lx swapped with Ex(vtec engine)
  18. 2002 civic engine swap
  19. can an a/t ecu for d17a2 be converted to m/t
  20. 2005 motor swapped to a 2001 car
  21. 2005 honda civic d17a1 to a jdm d17a with vtech
  22. Engine Swap Questions
  23. 05 lx a1 to ex a2 swap questions
  24. D17A2 motor swap questions
  25. 2001 civic automatic to manual ecu conversion?
  26. D17a1 to d17a2
  27. Complete Swap from D17a1 to D17a2 need advice
  28. D17a1 to D17a1 block with a2 head
  29. The usual vtec swap questions.
  30. D17A2 swap to D17A JDM engine
  31. Swap
  32. Non Vtec to Vtec swap
  33. D17 from JDM
  34. Swapping a non vtec engine into a vtec car
  35. 03 civic vtec with non vtec engine
  36. Code Reader cannot communicate with ECU/PCM - Guide for stock ECU swaps
  37. Engine swap?
  38. Transfer engine from 03 DX to 04 DX
  39. d17a1 to d17a2 swap, low on top end power
  40. 2003 Civic LX ENGINE SWAP HELP
  41. Can 01-03 civic d17a1 engine be used in an 04 Civic LX?
  42. D17A2 Auto Engine to D17A2 Manual Body Swap
  43. D17A2 to D17A O2 sensor question. TIA
  44. 1.7 non vtech engine in vtech car.
  45. d17a2 swap to JDM d17a2
  46. Introduction and 04 EX Transplant success!
  47. Need to know swapping D17a2 auto/manual car
  48. After D17A1 to D17A swap no fuel pump.
  49. D17A1 Turbo & Bolt-ons Help
  50. 04 DX Engine Swap
  51. questions on D17A motor and tranny swap in place of d17a1
  52. E1 to E11??????
  53. D17a?
  54. Vtec and Non-Vtec Engine Swap
  55. Swap VTEC for D17A1-2004 model
  56. D17a2 bottom end with d17a1 top end
  57. Direct Motor swap question
  58. Interchangeable engines
  59. D17A2 swapped to JDM D17A, help please.
  60. d17a1/a2
  61. wiring 1.7L SOHC stock ECU nonVTEC-to-Vtec Swap
  62. O2 Sensor ECU Wiring from LX-EX Check Engine
  63. 1.7L SOHC Non-Vtec Swap
  64. d15y2 vs d17a
  65. picked up an 05 special edition
  66. LX ECU SWAP for an EX ECU 04-05 EM2
  67. D17A1 Swapped out for a D17A (issues)
  68. D17 swap No EGR to EGR
  69. 04 DX to 04 EX swap help required?
  70. RevLimiter on 4k RPM after Engine Swap from Vtec to none Vtec with new programmed ECM
  71. D17a2 VTEC-E discussion
  72. My D17A6 to JDM D17A Engine Swap Thread
  73. Civic em2 with d16w7 engine(from D17a8)
  74. d17a2 and d17a6
  75. Couple Questions About D17A1 to D17A2
  76. Engine Help 2004 Civic
  77. d17a/ d17a1/ d17a2 difference?
  78. JDM d17 motor swap question
  79. Whats price range for mechanic to swap engine?
  80. Motor and Transmission swap help???
  81. Non Vtec to Vtec swap!!! HELP!
  82. D-Series Engine and Transmission Specifications..
  83. The ultimate DX/LX vs EX header/exhaust DIY and FAQ
