SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
D17A1 swap into an EX that had a VTEC D17A2?
Old Sep 26, 2022
gts's Avatar
gts
gts has a spectacular aura aboutgts has a spectacular aura about
I bought what I thought was a used VTEC (D17A2) engine but my mechanic found out it doesn't have the oil solenoid for the VTEC and says it's not a VTEC Engine. So it seems I bought D17A1 (arggh)
He also said something about the solenoid holds the bracket that attaches to____ but that it's not an issue if I want to put the D17A1 in.
So what are the implications of putting a D17A1 into my 2003 EX that had a D17A2?
I read about limp mode but not sure what that means? No rpm over 3.5/4k? So no acceleration?
I'm also concerned about emissions test failure therefore not passing inspection.
Any insights and help is appreciated.
Old Sep 26, 2022
Re: D17A1 swap into an EX that had a VTEC D17A2?
mentioned on your other thread - ECU will be looking for VTEC where there is none - return the engine if you can
Chadbrailer
26
Jul 16, 2021 04:57 PM
Gaytac0
Transmission
Feb 23, 2020 09:52 PM
FSTBLK02
Jul 3, 2007 03:37 PM
CivicMexicano
Sep 26, 2006 01:04 PM
