SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
2005 honda civic d17a1 to a jdm d17a with vtech
Old May 6, 2020
Ilovelucy1214's Avatar
Ilovelucy1214 is an unknown quantity at this point
Ok here are aome questions i bought a 2005 honda civic perfect interior needs two fenders kinda and 2 headlights the motor was blown for 200 bucks i know jdm motors are like 500 bucks so i bought it now the jdm motor is a vtech need help kus my honda isnt vtech and the guy said when putting it in leave the vtech unplugged i dont know what he was talking about also will this leave me with a CEL is it possible that the honda civic wont know the motor wont have vtech and my harness wont have a plug for it pleaseee dieing for answers
Old May 6, 2020
FRSam's Avatar
Click Here
Re: 2005 honda civic d17a1 to a jdm d17a with vtech
It’ll work, but since your wiring harness won’t have the connector for the VTEC solenoid, it will throw a code.
Old May 6, 2020
BrotatoChip's Avatar
Super Moderator
It will only throw a code if using a VTEC ECU. If using your stock ECU it will not throw a code.
Old May 7, 2020
KX Hernandez's Avatar
KX Hernandez is an unknown quantity at this point
so do i just leave it unplugged or shoud i plug in the other plug that would normally go there
Old May 7, 2020
should i plug in the plug that normally goes there or should i leave it unplugged
Old May 7, 2020
Super Moderator
If you're using your stock engine harness you won't have a plug for it. If you simply want a running replacement engine with no faults and are using the stock ECU just leave the VTEC solenoid alone. If you actually want VTEC to function you will need a VTEC ECU or a VTEC controller and then wire in the solenoid. Multiple threads available discussing how to do this.
Raidon04
Oct 6, 2007 06:02 PM
steven10
Aug 8, 2005 01:09 AM
chester
Jun 12, 2005 08:38 AM
curbsquirrel
Engine Swaps
17
Jan 16, 2004 09:02 PM
