E1 to E11??????
E1 to E11??????
Hi i just recently swapped my 05 d17a2 for a 02jdm d17a and i did everything basicaccally myself but i cant turn the car on and i was told i needed to change my wiring from E1 to E11 but i dont really know how the hell to do that so can i get any help bros???!!!!
The legs in the public bathroom stall
Re: E1 to E11??????
What does the car do or not do?
Does it crank?
Does it light up the gauges? (including check engine light)
Have you checked your engine ground cables?
Does it make funny noises and try to hide in the closet?
Did you change the PCM?
Did you change anything else during the swap?
What components were retained from your original engine (ie sensors)?
Does it crank?
Re: E1 to E11??????
Lol well now im running it with the US ecu and it starts doesnt make any noises and runs perfect up untill i reach the freakin 4k rpms then it just bounces off just like a rev limiter but i dont think its in limp bcause its pefect in idle and yea everything is lit im talkin check engine, abs, and aibags i did not change my pcm and rn im trying to put on the STOCK US harness on to see if it fixes it
Re: E1 to E11??????
You must use the cars original engine harness and PCM.
You need to install the pressure switch from your original VTEC valve into the VTEC valve on the new D17a engine, and connect its wiring JUST LIKE ON THE ORIGINAL ENGINE. (or swap the complete VTEC valve assembly, whatever is easiest for you)
If your original engine had EGR, the new engine needs to have it too. JUST LIKE ON THE ORIGINAL ENGINE.
WTF is this supposed to do?
Re: E1 to E11??????
Yea and it seems evrything is getting better i fstened my stock harness on yesterday and now i can rev it up to redline, but now i just need vtec to kick inn goddammitttt ima take it to the shop ina bit so they can run a scan on it yee thank u guys so much for the help
Re: E1 to E11??????
You've got the original D17A2 ECM?
You've got the pressure switch installed and hooked up on the VTEC valve?
You've driven it on the road, floored it and run all the way to redline?
No fault codes set now, no limp mode?
What makes you think VTEC is not working?
Re: E1 to E11??????
Yea bro i have the d17a2 ecm + harness + vtec solenoid in there and it still dont work maybe its a fuse? A sensor? Uuuh maybe the solenoid doesnt work or maybe the ecm???? Ill scan it tommorrow and hopefully try to find out wats goin on😟
Re: E1 to E11??????
Re: E1 to E11??????
also when im on the highway it throws my 5th gear out and i have trouble sometimes putting it in reverse its so ****ing anoying u have any idea wats ****ed up? Or what part i should replace?🙃
Re: E1 to E11??????
You still didn't answer these:
Re: E1 to E11??????
Did it have a trans problem before or is this not the same trans as before?
Trans fluid full? Shift cables right? SHifter not binding?
Re: E1 to E11??????
i havent checked the fluid
does it take any?
does it take any?
Hope it's not ruined already.
Re: E1 to E11??????
well yea in reverse it just wont bind itll slide right out like theres nothing to hold it there sometimes and when im in 5th itll just randomly throws it out that bitch
Re: E1 to E11??????
so i figured any tranny oil it had was good
Did your engine come already filled with oil?
