SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
After D17A1 to D17A swap no fuel pump.
Old Oct 4, 2017
mike57's Avatar
mike57 is an unknown quantity at this point
2004 Civic LX swapped D17A1 non Vtec to D17A Vtec, now I have no fuel pump voltage. All fuses and relay checked, any ideas?
Old Oct 4, 2017
Re: After D17A1 to D17A swap no fuel pump.
Forgot to bolt down the set of ground wires on the upper radiator hose neck?
Old Oct 4, 2017
mike57's Avatar
All grounds attached and checked with ohm meter. Did not swap crank and cam sensors from old to JDM.
Old Oct 4, 2017
That should be the same as long as the new ones are good. The only thing that isn't plug and play is the VTEC that wasn't on the D17A1 engine.
Blown fuses in either fuse box?
Both of these grounds clean and tight? The small wires are for the PCM and just about everything related to powertrain controls.
(pic)
Old Oct 4, 2017
mike57's Avatar
All fuses good, no codes, ran hot wire to verify pump good.
Old Oct 4, 2017
Then I'd get a wiring diagram and start checking the 4 circuits of the fuel pump relay to see which leg is missing, then I'd have a direction to go from there.
Anything else missing? Got spark? Got injector pulse?
Old Oct 4, 2017
mike57's Avatar
I found that pump will prime but shuts off after engine starts.
Old Oct 4, 2017
So...engine runs 2 seconds maximum?
Do fuel injectors also lose their ground "pulse" from the PCM at the same time?
Check green key symbol, is it flashing rapidly when the engine shuts down?
Does the green key symbol act normal or not?
Have you checked timing belt/cam timing yet?
Assuming it shuts down at 2 seconds and the green key symbol is not flashing.....If you unplug the cam sensor, will it run longer than 2 seconds? Is it making a rattle noise when it runs?
