SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
Engine swap dx to ex
Old Feb 12, 2023
Dj fuze's Avatar
Dj fuze is an unknown quantity at this point
Can I use the non VTEC ECU and harness on the ex engine jdm swap if I'm block off the vtech is that possible
Old Feb 12, 2023
Re: Engine swap dx to ex
yes
the VTEC will simply be dead weight without the ECU that controls it
probably will work worse than original engine in higher RPM (only 3 valves working, hard to breathe)
potentia
Sep 21, 2017 07:55 PM
affixrider
Mar 11, 2008 11:57 PM
Jeff
Engine Swaps
Aug 27, 2006 08:56 PM
Hawaiian_Built
May 27, 2005 05:00 PM
preaves
16
Feb 20, 2002 11:25 PM
