SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
1.7l to 1.3l swap
Old Mar 29, 2022
Handsome_rob89's Avatar
Handsome_rob89 is an unknown quantity at this point
1.7l to 1.3l swap
I've got an 04 civic with the 1.7l vtec engine with a hole in the block, can I replace it with a 1.3l engine? I assume I would need an ecu at least or am in for trouble trying to swap that way 😅
Old Mar 29, 2022
Re: 1.7l to 1.3l swap
the hybrid engine? It have two spark plugs per cylinder (starts from there, many other differences)
the hybrid also have the electric motors to help push the car, yours don't. potentially will have similar mileage since you will need to punch throttle more
ECU will be looking for the electric powertrain but it is not there, forecast plenty of engine codes
complicated and not worth
why do you want to do it?
Old Mar 29, 2022
because I can get the engine for $150, just trying to not drive my diesel truck 20 miles to work each day and not wanting to spend a ton on a swap, cheapest 1.7 ive been able to find was around $1600.
Old Mar 29, 2022
BrotatoChip's Avatar
Super Moderator
Where are you looking? You can get a JDM D17a with like 50k miles for $900. I would expect a regular D17a1/2 would cost $500.
Old Mar 29, 2022
Mostly local junkyards and Facebook, online wasn't much better. I want to keep the engine around $500 but the cheapest I could find was 1200 with 170k miles not 1600 🤥
Old Mar 29, 2022
Colin42's Avatar
Stick to a 1.7L
Old Mar 29, 2022
FRSam's Avatar
Click Here
https://jdmautopartsusa.com/en/honda...19/honda-d17a/
https://www.jdmsource.ca/products/20...-ex-1-7l-d17a2
I refuse to believe that anything junkyard can't be had for anything more than like $400. Find a totaled car and pull the engine from that.
Old Mar 29, 2022
what is the engine you are looking for? Is it from a Hybrid?
that is sounding like it could balloon pretty fast into the 2k range to fit that engine
Old Mar 29, 2022
that's what I'm afraid of lol just want to get it fixed to commute for cheap.
Mcooke
Sep 15, 2021 12:54 AM
Creativeusernam
Feb 11, 2020 11:36 AM
tommyd5806
Engine Swaps
Oct 28, 2011 04:44 PM
revs28g
Jul 9, 2008 11:28 AM
criminal
Feb 18, 2003 09:03 AM
