dohc swap?
Old Feb 17, 2003
criminal's Avatar
criminal is an unknown quantity at this point
dohc swap?
sorry if this topic has already been discussed but i searched and found nothing, but does anyone know if we can do a head swap and if so with what engine and what kind of power could be gained?
Old Feb 17, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
nah unless you want to swap another d17 civic head
Old Feb 17, 2003
JohnnyLee's Avatar
7thgen guh chee
i don't think so
Old Feb 17, 2003
cambo's Avatar
I wish I was asian
a SOHC cannot be turned into a DOHC. the dynamics of the engine and components are too different. only way is to totally swap the engine for another. Adding VTEC to a non-VTEC engine is a different story. some can, some cant
Old Feb 17, 2003
nutrawk669's Avatar
nutrawk669 is an unknown quantity at this point
Quote
[hr]Originally posted by: criminal
sorry if this topic has already been discussed but i searched and found nothing, but does anyone know if we can do a head swap and if so with what engine and what kind of power could be gained?[hr]
Yeah, you'd have to swap in a head from the same gen o' civic. Either it's not possible to put a head from a k20 on a d17, or people have done it and aren't telling, but it's a pretty safe bet that it's not possible. If you're looking to do the conversion from LX or DX to EX(head/ecu/timing swap), then yeah it is possible. Just pop the head, timing belt and ECU off a D17A-whatever-it-is for the EX thingy off, pop it on your car. Yay.
As far as cost, it's not exactly cheap. Figure about $3-500 for the ECU and about that for the head, and who knows for the belt. Your performance boost will be exactly 12 horsepower, which is the difference between the EX and LX or DX or whatever. It will, however, yield more of a performance increase than a p/p and a re-bore, and you'll be able to get a wee bit more out of those mods, but IMO if you're going to do something like that to your Civ you can also do a k20a2 swap, which in the long run is more cost-effective. Double your power and leaves your car to respond better to any upgrades. Expect to spend upwards of $7k for a k20 engine swap.
Somethin' to think about.
Old Feb 17, 2003
Ducatti's Avatar
Ducatti is an unknown quantity at this point
You cannot swap between different engines. For instance, a K series head cannot go onto a D block.
Old Feb 18, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Quote
[hr]Originally posted by: Ducatti
You cannot swap between different engines. For instance, a K series head cannot go onto a D block.[hr]
Says it all right there!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
