SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
D17A2 motor swap questions
Old Aug 23, 2019
Kasha Zimmerman's Avatar
Kasha Zimmerman is an unknown quantity at this point
Quick question,
I'm doing a A2 swap for my 7th gen, and I was wondering if I can use me CAI and Header/Downpipe from my A1?
Old Aug 23, 2019
Re: D17A2 motor swap questions
I don't see why the intake couldn't work. TB's are the same, and as long as you're keeping the same type of tranny and not swapping from AT to MT or MT to AT, it should mount up the same.
The header/downpipe will bolt right up, too, but the difference is going to be in the O2 sensor wiring, or rather, the physical location of the sensors in the exhaust stream. On the D17A2, the O2 sensors are below the car, just about under the shifter console. On the D17A1, they sit forward of the engine. That coincides with where their respective catalytic converters are: D17A2 under the car, D17A1 integrated into the OEM exhaust manifold. If the -A1 header you have has the O2 sensors installed on the header, you'll have the either extend the wires or switch to the -A2 exhaust setup
Old Aug 23, 2019
Okay, and yes I'm keeping auto. That is a huge relief, the motor came yesterday and I'm going to take care of everything before I drop it back in. Motor mounts and everything.
Old Oct 4, 2019
Corey Clark's Avatar
Corey Clark is an unknown quantity at this point
i have a d17a1 and i just got given a d17a2 can i just take the head, harness, ecu , and immobilizer and put it in my car for vtec?
Old Oct 4, 2019
BrotatoChip's Avatar
Super Moderator
Basically, yes.
You might as well just take the whole engine, in my opinion replacing the entire engine is easier than swapping just the head. Anyways, you'd need the engine/head, harness, ECU, and the ignition assembly including the immobilizer and keys. You will also have to wire up the secondary O2 sensor since it's part of the body harness on the EX Civic. Just swapping everything will give you VTEC but will throw a fault for the sensor until it is wired.
Here's some info on the wiring:
https://www.civicforums.com/forums/3...ck-engine.html
Old Oct 5, 2019
I ended up using the new harness, and old ECU, since i didnt have the EGR wiring, which will be a project for another day. So currently, im thinking im in limp mode, i hit rev limiter at 4grand.
Canadiancivicsi
Bolt-on Engine Performance
Mar 3, 2017 02:04 AM
Bxking126
May 22, 2011 04:53 PM
bajancivc
Jun 5, 2006 01:24 PM
TQ_
Mar 23, 2006 07:59 PM
down_
Nov 7, 2004 10:22 PM
