PDA
View Full Version : Wheels, Tires & Brakes Modifications
Pages : [1] 2
  1. Setting a 2008 civic up as a racecar
  2. Upgrading to larger brakes but keeping 16 in rim size
  3. Caliper size on LX the same as DX?
  4. what sort of improvement was made on Anti-Lock Brake since 2010
  5. Installing Wrong Tire Size. [solved]
  6. Will these tires/rims fit my car??
  7. Lug Nuts
  8. S2K rims R18 Chassis
  9. Will 16” rims fit on a 2007 EX 4DR?
  10. New wheels
  11. New look Civic hubcaps on 2006 Civic
  12. Tire cover warped after cold winter
  13. 08 Civic Stock Wheels
  14. rear drum to disc brake conversion
  15. Winter Tires
  16. 2006 Civic Rims on a 2015
  17. What are the best Rotors for a boosted civic
  18. How to stance a 2008 Civic Coupe Dx on coilovers
  19. no TPMS sensors on new rims
  20. Tires for 2015 EX Sedan
  21. Wheels and tires 2012 lx
  22. 4 To 5 Lug
  23. SI wheels on 2011 LX
  24. question about wheels and rims
  25. 225/40/18 18x8.5 +35
  26. new rims without TPMS sensors....
  27. Winter tires
  28. Better wheels pressure
  29. 6 years old tyres but good tread, should I replace them?
  30. Broken TPMS sensor - Easy fix
  31. Best batteries for TPMS Replacement?
  32. Tire size
  33. Wheel fitment help!
  34. 2012 Honda Civic LX
  35. Honda Civic 2013 LX - Wheel and Tire Fit
  36. will these wheels fit?
  37. 2015 Honda Civic EX
  38. Steel or Alloy Rims ?
  39. What wheel size would look good?
  40. 2018 civc 18 si wheels 18x8 50+ offset will fit 9th gen with stock height
  41. Hybrid wheels
  42. 17 inch wheels - Can't tell what trim they came from
  43. Getting new wheels
  44. Brake scam?
  45. General: Rims, rear disc brake conversion, muffler
  46. Need assistance determining what wheel cover size I should buy.
  47. tpms 2010 civic and ABS
  48. wheel offset
  49. wheel dimension
  50. Bad tpms sensor
  51. 2014 civic coupe rim upgrade oem lug nut question
  52. TPMS reset question
  53. TPMS light
  54. Time for Tires
  55. ‘04 CRV wheels on my Mark IX
  56. NEWBIE question - Will these fit? Neighbours rims
  57. Silver or black rims?
  58. New Tire Purchase
  59. 2015 Civic first time brake fluid change
  60. Thoughts on the Goodyear Eagle LS (or a similar priced tire)
  61. 2012 EX-L TPMS Question
  62. Stock Wheel Cover/Hubcap options for 2013 Civic 4D LX?
  63. Possible upgrade on wheels and tires 2015 Civic SE
  64. Traveling long distance when braking
  65. changed tires and.....
  66. Tires and Rotation for 2015 Civic EX
  67. Which Tires
  68. 08 honda civic-body shakes while breal is applied travelling downhill
  69. Do I need new rotors?
  70. Difference between brake pads?
  71. Steel Wheels for my 2015 EX
  72. Need to change brake pads and rotors
  73. Best specs for rpf1s?
  74. from 215/45-17 to 215/50-17 (2015 EX-L)
  75. 2006 Civic EX Coupe Brake Advice?
  76. What do you guys think?
  77. Need the parameter of brake -- Civic 2012
  78. 2015 Honda Civic LX - replace TPMS Sensor after new tires?
  79. 2015 Honda Civic LX - Quietest Tires?
  80. Steering wheel servo adjustment
  81. Front Wheel Bearing Replacement
  82. ABS/Brake light
  83. Need some help
  84. 2014 Civic EX with F/R Disc Brakes
  85. Tire Replacement
  86. TPMSlight is on
  87. Proper Aftermarket TPMS Sensor Replacement Part?
  88. Aftermarket Wheels for a 2009 EX-L coupe
  89. What pads ?
  90. Anyone have Uniroyal Tiger Paws on 2006 Civic?
  91. Recommend good (cheaper) summer tires for 2006 Civic
  92. Brake hose
  93. 2013 Honda Civic LX - Upgrade Tires from 15" to 16" ?
  94. E Brake adjustment
  95. Front right squeal 2014 civic
  96. rear wheels make clunking sounds when braking
  97. 2009 ex Civic, need help with tires
  98. Winter tire suggestions?
  99. Winter rims/tires for 2012 EX sedan
  100. ABS Sensor
  101. Shudder and vibration when braking downhill mountain road
  102. I need help with wheel size/options on 2010 civic
  103. 2007 Civic - wheels, spacers, suspension, etc
  104. brake bleeder
  105. Wheels and Tires For my 13' Civic Si Sedan
  106. Canadian 2008 Civic TPMS Compliance
  107. Driver side front wheel squealing
  108. torque values , brakes 2010 lx-s
  109. Whats the right size for my honda civic 210
  110. Top Tires?
  111. Rotor/brake pad/caliper suggestions
  112. Hit a light post with my wheel.
  113. spare tire ok ?
  114. 2006 Honda Civic ABS Indicator Light
  115. Front pads /rotor recommendation
  116. 08 alloy wheel on a 2010 LX-S?
  117. choosing Enkei wheel nuts, what to watch out for ?
  118. Leaky tires/corroded rims?
  119. 1994 Mustang wheels on a 06 civic
  120. Question about winter tires for Honda Civic 2010
  121. Prealignment Inspection
  122. Brake Caliper Failure
  123. WTF happened with these brake disks?
  124. Lightest rims and questions about stretched tires
  125. 2007 Civic wheel studs
  126. i need some help with rims and tires
  127. OEM wheel sizes and upgrading
  128. Brake Shoe Reccomendation
  129. 2008 honda civic brakes
  130. Replacing brake fluid
  131. recommend snow tires
  132. TPMS calibration
  133. Best place to buy OEM tires and increase mpg?
  134. Why/How were these brakes working?
  135. Rear caliper rebuilds
  136. New SI - Tire Balancing
  137. Don't know how low or what size wheel.
  138. Brake Pad Wear
  139. can I fit 17" mb battles on my 2010 civic sedan lx
  140. grinding noise from brakes when locking up
  141. outer edge of rotor NOT contacting pads. AGAIN
  142. 06 EX Brake System Upgrade
  143. brake drums
  144. Weird? brake pad wear
  145. Klutch Wheels // KM20 // Official thread
  146. I have proof 15 inc wheels work on a generation 8 Civic
  147. Klutch Wheels // SL5 // Official Thread
  148. Clicking noise when pressing gas pedal
  149. 2015 Klutch Wheels Line up
  150. HELP! 225/40/18 Si rims 2014
  151. Klutch Wheels Black Friday Sales
  152. Civic issue with frozen brake calipers?
  153. lining up piston w/ pad tab
  154. Buying Brake Pads ...from Amazon vs Pep Boys
  155. How to pick rotors?
  156. Klutch Wheels Official Thread
  157. Need Tires Soon
  158. Rotors - Two part numbers for one part
  159. 2007 Honda Civic Si Tire Help
  160. brake questions
  161. Tire Fitment and Tire Pressure Monitoring System Replacement Question
  162. Bad Brakes & Rotors?
  163. Rims 2014 Civic Coupe
  164. Noisy Right Rear
  165. Klutch Wheels | SL5 | Silver Machined
  166. Tire Fitment
  167. Wheel Suggestions for 2007 Si Fiji Blue
  168. Rear Drum to Disc conversion ?
  169. Fitment Question - 195/60/15 on 2013/14 Civic
  170. Wheel Spacers
  171. wheel problem
  172. Wider Tires 2007 civic si
  173. Update on class action lawsuit for brakes?
  174. Replacing the DX hubcap steelies with some RSX rims. Anyone else rockin RSX's?
  175. How to know a good brand of brakes are used?
  176. Can I fit 18x8F 18x8.5T on my 2012 civic ex-l?
  177. '06 coupe 1st time tire choice help
  178. Wheel Question
  179. Klutch Wheels: Open House
  180. Do tires always make noise just before losing traction?
  181. will this settup work?
  182. 17 in wheels, too good to be true?
  183. Best tires for 2006 Si?
  184. Wheels/Upgrades
  185. Klutch Wheels SL14 on Civic Si
  186. Wheel locks
  187. 16" Aftermarket Wheels
  188. Got 17" Lexus wheels, stock wheel studs ok?
  189. Winter rims offset
  190. PA- 2011 civic Coupe. squeaky front brakes
  191. Klutch Wheels: First pics of SL5 on Honda
  192. Klutch Wheels Custom Gloss Black SL14 : Civic Fitments Available
  193. Rims width that can fit ?
  194. Offset not understood...?!
  195. Klutch Wheels Help us Decide!!
  196. Question about tires and Rims HELPPPPP!!
  197. Need performance calipers w/out kit?
  198. Brake Pads/ABS
  199. Ceramic pads ???
  200. Wheel size.
  201. Klutch Wheels: Perfect fit for Honda Civic
  202. 06 Civic and 18's... slow me down?
  203. '08 civic hybrid brake life
  204. Opinion please
  205. Vibration while braking at highway speeds
  206. Steel wheel center caps.
  207. 2000 Honda civic lx sedan car tires 185/70/14 or 185/65/14??
  208. What wheels are popular for a honda civic coupe?
  209. SL1 KLUTCH WHEELS on CIVIC EK
  210. sound from the back wheel on the driver side
  211. Weird noise. Brake pad alarm?
  212. What rims should I Get?
  213. Winter tires on my current RIMS?
  214. Brake upgrade?
  215. Klutch SL1 15x8.5 3.5" , 16x8 3", 16x9 4" step lip now available!
  216. Klutch SL 14 on VW EOS! Civic fitments available!
  217. Suspension noise after installing 17in wheels?
  218. Anyone have experience with the X-ice Xi3?
  219. rear brakes 07 Civic - compressing the piston back into the caliper????????
  220. New Klutch SL 14 on FR-S! Now Available for 8th, 9th Gen Civics!
  221. Brake upgrade-my weekend project
  222. Tires keep exploding.
  223. em2
  224. anyone know of good websites for wheels?
  225. WTB: OEM Civic EX or LX-S Rims
  226. Best bang for the buck mods?
  227. Best brakes for Honda Civic- read reviews, install videos and more!
  228. Rims? Lx 2007
  229. Will CRZ wheels fit an 09?
  230. Brake noise? Backing up.
  231. Drum to Disc Brake conversion
  232. TPMS is still lighted? Fixes?
  233. factory steel wheel question 09 civic
  234. Replacing Drum Brakes with Disc Brakes
  235. Brake Pad suggestions for 09 CRV?
  236. Car Pulling Left
  237. Si Brake Upgrade
  238. Need Help!
  239. HFP rims
  240. 02 civic ex tire suggestions
  241. ABS Light
  242. Newbie please help: 2008 civic lx tire pressure
  243. will 19 inchrims fit my 07 coupe??
  244. Satin black powder coated Enkei Rims for Honda - $400 (campbell)
  245. Bolt Pattern Question.
  246. Brake Rotor screws
  247. Front break pads went bad quickly?
  248. Honda Civic Si brakes not working?
  249. Wheel Fitment Guide.
  250. Will these work for 2012 exl
