Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
wheel problem
Old Nov 9, 2013
rickeyfast's Avatar
rickeyfast is an unknown quantity at this point
wheel problem
Ok so you guys are going to laugh at me but I need your guidance...
I picked up some honda oem rims with winter rubber from craigslist... the bolt and and bore appear fine, but I think I am having an offset issue. I am not sure what car the rims were on.
I was told they would fit 08 civic.
When I have the rims on, the car won't move... I am assuming that the offset is off.
I have an 08 civic, these are oem Honda rims but I don't know the specs.
Rims are 15" and have 195/65/15 rubber on board.
Would 5mm spacers help?
Any safety issues with using spacers?
Thanks
Old Nov 9, 2013
Re: wheel problem
See if a rim is hitting a brake caliper.
Whatever is causing the problem should be easy to find with careful observation.
honda200192
May 31, 2015 05:57 PM
cmart1209
May 29, 2015 04:52 AM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
RickyRocket
Nov 30, 2001 10:14 AM
