Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
changed tires and.....
Old Apr 22, 2018
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
Hey guys
ive putted my summer tires on and when i drive it shakes and makes a wobbling noise.
https://www.youtube.com/watch?v=p7Ql...ature=youtu.be
When i switch tires i dont mark them down to see which was were, I just install them randomly. Maybe its that. Or maybe they became off balance, didnt have that problem last summer.
What could it be?
Thanks in advance!!!
Old Apr 22, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: changed tires and.....
at a decent tire shop, the tires that take the most weight to balance are normally placed in the rear. you might look at the weights stuck on the rims and move them accordingly. if it were me, i would inspect them for lumps and then have them rebalanced, as it is cheap, quick, and should help. you should spend 5 minutes picking any rocks or crap out of the tread before you have them balanced, as you likely care more than the guy at the tire shop.
i'm assuming your lug nuts are on right and the hub/rim mating surfaces are flat and burr/debris free
Old Apr 22, 2018
ive found the solution.
on the driver side front and back. the front weight was .75 and the back one was 1.0, i switch both then i made sure both tires behind were the lowest in weight and then i took off all tires. cleaned the threads and put them back good.
No problem anymore, runs smooth. thanks.
and no need to go balance them
Old Apr 22, 2018
im wondering, would buying a bubble wheel balancer be a good investment or its not worth the hassle.
Ckutch02EX
Aug 7, 2012 10:19 PM
Boods
Aug 8, 2006 08:37 PM
silverem2
Bolt-on Engine Performance
Sep 16, 2004 02:38 AM
civicdude
Mid Atlantic
17
May 28, 2003 05:36 PM
inca
Sep 2, 2002 10:10 PM
