Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
What are the best Rotors for a boosted civic
Old Sep 18, 2021
Blakethesnake's Avatar
Blakethesnake is an unknown quantity at this point
I brought my car to the tracks, and after some burn outs and other degenerate activities my rotors are squeaky assuming they warped from all the heat and play
are their rotors specifically designed to prevent warping because the most expensive ones at autozone suck and didnt even last 2 months
thanks !
Old Sep 18, 2021
FRSam's Avatar
Click Here
Re: What are the best Rotors for a boosted civic
What kind are you using? Drilled/slotted rotors are designed to dissipate heat but life is reduced dramatically. You may only get 2 months depending on how hard you drive it.
Old Sep 18, 2021
I believe duralast gold rotors, hopefully my breaks aren’t to uneven got both replaced 2 months ago. Should of noticed sooner cus how much break dust was coming on the rims
Old Sep 18, 2021
what kind of track?
If roadtrack, the pads likely glazed. consider installing one step above pads before heading to track. road track you are not likely to do burn-outs, so don't think it's your case, though.
If drag strip, shouldn't have caused that much issues.
can't remember how to solve that one without changing pads.
stay away from drilled rotors, just search about cracked drilled rotors. Even properly designed ones carry risks
Old Sep 19, 2021
Originally Posted by sdaidoji
what kind of track?
it was a drag strip , with a huge overflow parking lot where we did dumb ****. Sometimes we do highway driving and do some pulls on there me and friends. I do break a bit harder at times but maybe I just had junk rotors or pads.
only driver side squeaks and has excess dust otherside is fine.
is there an easy way to tell if it’s a glazed pad or a rotor issue? --- I know its a rotational squeak, and itll stop once the breaks are being pressed, but makes noise at slow speeds under 20. Breaks n rotors are 2 months new as said, only one side is doing it. and alot of break dust same side
Old Sep 19, 2021
Eh.. slight correction there. Heat dissipation is a secondary function. Drilled rotor design is primarily for outgassing, slots are for both outgassing and, for a lack of better words, resurfacing pads preventing glazing. Downside, like you mentioned, is pad life is significantly reduced.
@Blakethesnake I've heard nothing about good things about R1 concepts brakes, but have yet to try them myself. Good performance at a decent price. However, their stock on everything seems to be low af right now.
Old Sep 19, 2021
simple. if glazed, your stopping power goes down. Looks like this is not a glazing problem.
lift car.
remove wheels
inspect. sometimes it's the BRAKE shield that is bent and making the noise.
mradam85
Nov 4, 2004 03:47 PM
civicfreak84
47
Jun 12, 2004 04:40 PM
silverem2
Dec 4, 2003 07:55 AM
blckpwdr
Sep 25, 2003 11:26 PM
civicex2002
Jun 29, 2003 04:41 PM
