Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Got 17" Lexus wheels, stock wheel studs ok?
Old Apr 10, 2013
JrFreak's Avatar
JrFreak is an unknown quantity at this point
I got a nice set of 17" Lexus wheels for my Civic to run summer rubber. I know I need to pick up new lug nuts, but I'm not sure if the stock studs are long enough?
Anyone know off the top of their heads? The stock thread is M12x1.5, correct?
Old Apr 10, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Got 17" Lexus wheels, stock wheel studs ok?
Best way to figure it out is to try and install them. Should be fine though. Hopefully you don't run into any other issues with the rims not fitting though.
Old Apr 10, 2013
JrFreak's Avatar
Did some measurements. The stock studs should work. I didn't want to have all 4 wheels off and find out I need to run to autozone for parts =/
Old Apr 15, 2013
JrFreak's Avatar
Ok. Ran into an issue. Need help!
The hub diameter on the Honda is 2.5", but the inner diameter of the wheels start at 2.5" but taper to 2.375". This is keeping the honda drum hub from going into the wheel. I tried to give the drum hub a slight chamfer, but it isn't close to helping. Looks like I'd need a 1/4" or so thick spacer and longer studs. I don't want to do that though.
Any ideas? I spend $1200 for the wheels and fresh rubber. I'd HATE to have to try and sell these.
EDIT: Ok, did some research. Honda hub centric is 64.1mm and Lexus is 60.1mm. I wish the f'ing guy on eBay knew about hub centric. S.W.A.T. Motorsports on eBay... you'd think he'd know about that when all he sells on ebay is wheels...
Anyways. Looks like I'll just have to sell them and get wheels with 64.1 hub centric....bah.
Old Apr 16, 2013
BlueEM2's Avatar
Whachya lookin at?
I think you need hubcentric rings but I'm not totally positive if that will fix it. Good luck finding them too. It might not work though... hmm.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
viciousvolpe
Dec 12, 2001 11:17 AM
VNlilMAN
Dec 6, 2001 01:25 AM
vtecharry
Nov 28, 2001 07:03 PM
htowncivicEX
Nov 13, 2001 04:30 PM
