OEM wheel sizes and upgrading
I was hoping to swap my factory steel wheels for some nicer looking OEM Honda alloy ones, but I realized the steel wheels are 15" in diameter and the alloy ones are all 17" or greater. Can anyone confirm this is the case? Am I out of luck trying to find 15" factory alloy wheels for a 9th gen Civic?
My hope was to get a different set of OEM wheels on Craigslist, but it looks like if I do that, I'll have to swap tires too.
Re: OEM wheel sizes and upgrading
You can go older than 9th gen and you don't have to stick with Civic.
There's an awful lot of 15" Honda and Acura wheels that use the same bolt pattern and will bolt right on. (research first)
Several other manufacturers use the same bolt pattern too, (research well first, hub size and offset are important)
I'm running 18" wheels from an 11-12 Accord V6 Coupe on my 12 Civic LX (original wheels were 15" steel). Pics in profile if you want to see them.
I snagged a set of lightweight Aluminum 15" wheels from a Hybrid and stuck my original tires on them for winter use....although I haven't done it yet, I've been running the 18" all year long since I got them LOL.
Thanks for the suggestions. I will widen the search and see if any good looking 15" Honda wheels with the right bolt spacing show up. I'd like to avoid aftermarket wheels because I want to keep the car as stock as possible.
You might peruse this thread on the subject (from a different forum) lots of pics
http://www.9thgencivic.com/forum/whe...ly-please.html
Get some cheap then fill in imperfections (with bondo?) and paint, powdercoat, or plastidip to your liking?
I would probably not spend the money to powder coat a set of banged up and bondo'd wheels, but rattlecan or plastidip might be workable.
I ave not used platidip but I hear good things about it.
denierlexiese
Aug 5, 2015 08:58 PM
qlitten
Jul 21, 2015 03:12 PM
hatch90
Jul 5, 2015 01:17 AM
