Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Tire Fitment
Old Jan 23, 2014
MetalliCHAD's Avatar
MetalliCHAD is an unknown quantity at this point
Tire Fitment
I tried searching for an answer but couldn't find anything definitive. My question is pretty conservative...
Will 225 / 60 / 16 tires fit on a bone stock 2011 Civic EX-L sedan ?
OEM are 205 / 55 / 16
Thank you !
Old Jan 23, 2014
Re: Tire Fitment
Couldn't give you a definitive answer about fitment, but I can tell you that it'll throw your speedometer (and odometer) off.
Old Jan 23, 2014
GolNat's Avatar
Prelude Owner
Re: Tire Fitment
Can't give you a definitive answer either but it should fit just fine if you are not lowered. Your tire width will increase some but less then an inch. I don't think any OE suspension components would be that close to the tire sidewall.
I would take a look to make sure there is nothing in the way.
Old Jan 23, 2014
Re: Tire Fitment
Does anyone know if there is a way to find out for sure? I found a calculator that said the speedo would be off (low) by about 4.5 MPH.
Old Jan 23, 2014
GolNat's Avatar
Prelude Owner
Re: Tire Fitment
4.5 is about right.
A way to know for sure? Use a calculator to determine how much of a change will occur between the tire width and height and look at your suspension and measure.
http://www.tacomaworld.com/forum/tir...5r16-225-60r16
Or find someone who has tried it before.
Old Jan 23, 2014
Re: Tire Fitment
4.5 mph @ 60mph. 7% difference per the miata.net tire calc. Bear in mind that after 10,000 miles, your odometer will record 700 miles short of actual mileage.
225 is a bit wide for 01-05, that's all I can tell you. Although, stock height might not be an issue.
Just out of curiosity, why that specific size?
Old Jan 23, 2014
GolNat's Avatar
Prelude Owner
Re: Tire Fitment
It's the iPhone
Old Jan 23, 2014
Re: Tire Fitment
why would you want to do that, if you don't mind me asking?
Old Jan 24, 2014
Re: Tire Fitment
Honestly because my wife's car needs tires and a friend of ours has these laying around that we could basically score for nothing... I'm not as worried about the speedometer as I am safety and rubbing issues. It's a 4 door sedan - no lowering, no nothing. It's an A to B no frills car that just needs tires. lol
Old Jan 24, 2014
Re: Tire Fitment
Overall diameter is quite big - likely on sped bumps will need be careful or free tire could take out fender liners.
If during corner you hit a hole or bump, it could also be a free tire taking out your fenders.
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
