Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Brake scam?
Old Dec 29, 2018
bymitten's Avatar
bymitten is an unknown quantity at this point
Question Brake scam?
Hello everyone,
I recently noticed that my handbrake was getting a little loose (I could pull it up farther) and my braking was feeling "spongy". I was having regular maintenance soon so I had Honda look at it for me. When I got my car back, everything seemed to be corrected but was told that my drum brakes only had 3mm left on them and should be replaced soon. Now, I'm not a huge car know-it-all (hence why I'm on this forum ) but I'm pretty sure the rear drum brakes on my 2014 Honda Civic LX DON'T have pads like the fronts do. I didn't question the service advisor as the info locked up my brain. lol
I've attached a picture of the service inspection checklist so you can see more of what I'm talking about.
This is a scam, correct??
TIA,
Steve
BTW, I found it convenient that there was an issue with my rear brakes now simply because I had mentioned something. The brakes have been inspected yearly and the last two checkups there were noted as good. Hard to believe they went for good to crap so fast with no hard braking.
Old Dec 29, 2018
Re: Brake scam?
they have shoes, but that is just what they put on the check sheet. They wear off and eventually need replacing, although on my 02, the shoes were like new at 95k miles, or so. Maybe they improved brake bias on the 9th gen.
simple answer - no, it's not a scam. Although it usually take a long time to get down a mm.
Old Dec 29, 2018
Colin42's Avatar
Re: Brake scam?
It's a generic sheet...
Those are the measurements for the shoes.
You're not getting scammed
Old Dec 29, 2018
bymitten's Avatar
Re: Brake scam?
Ahhhh! Thank you for the info! I just wanted to make sure as it seemed fishy to me.
TA,
Steve
Old Jan 4, 2019
Meanie's Avatar
Meanie is an unknown quantity at this point
Re: Brake scam?
Late to the party but as others have said, no scam. Drum brakes and shoes are a different breed from disc brakes and pads. Shoes will last twice, maybe three times as long as pads. The shop is obviously letting you know the thickness of the shoes and to keep an eye on them as they will need to be replaced soon. Brand new shoes are roughly 11mm thick. Therefore, at 3 mm remaining, you're well beyond 3/4 of original thickness.
Old Jan 5, 2019
Re: Brake scam?
Originally Posted by Meanie
Brand new shoes are roughly 11mm thick.Therefore, at 3 mm remaining, you're well beyond 3/4 of original thickness.
Correction: Brand new shoes have linings about 4mm thick.
OP: I somehow missed this thread. Must have been on vacay.
My dealer doesn't even stock brake shoes because we almost never try to sell them.
Old Jan 5, 2019
Meanie's Avatar
Re: Brake scam?
According to this guy, the thickness is 11mm. Could he be referring to the entire shoe? I don't believe a lining with only 4mm would leave the lining table at 7mm and only allowing 1mm wear before replacing? Considering the recommended replacement of a shoe is 3mm and less.
https://www.quora.com/How-thick-must...re-replacement
Old Jan 5, 2019
bymitten's Avatar
Re: Brake scam?
So at 3mm, my brake shoes are only 25% worn??
Meanie, I read the first post from that link you provided. The poster there says "brake pads", not shoes. So I think he's referring to the front brake thickness.
Old Jan 5, 2019
Re: Brake scam?
no drum shoes that thick that i ever seen, even in semi trucks. They are enclosed into the drum, they would overheat
4mm sounds correct
Old Jan 5, 2019
Meanie's Avatar
Re: Brake scam?
You're correct. I overlooked the subject line of "Brake Pads". I'm still dumbfounded that shoes are only 4 mm but when they hit 3 mm, it's suggested they are replaced. I know shoes last longer but 1 mm compared to an 11 mm on pads and they still last longer? By your logic, you would be correct in assuming only 25% worn.
I've done many brake repairs on my own vehicle, family and friends, though never gave it a thought of pad/shoe thickness. If you view a metric ruler, 4 mm isn't much, enhancing my confusion trying to envision that thickness on a new pair of shoes.
Old Jan 5, 2019
Meanie's Avatar
Re: Brake scam?
4mm sounds correct
I would tend to agree, but similar to discs and calipers, you retract the piston for fit of new shoes and they make contact when first applied after install. Then, of course, you have the auto adjusters, as well. Perhaps not as thick as pads at 11 mm, but I still find it difficult to believe they are 4 mm brand new.
Old Jan 5, 2019
Meanie's Avatar
Re: Brake scam?
I just did a search for average thickness of new drum shoes and came across a few differences based on vehicle brand and type. The thickest I cam across was 5 mm for a Prius and they suggested replacing at 1 mm. I learned something new today.
Old Jan 6, 2019
Re: Brake scam?
no problems - I do mistakes everyday
Old Jan 6, 2019
Re: Brake scam?
3mm is for disc brake pads, not shoes.
FSM says replace shoes when they are worn to 2mm
Saratoga
26
Oct 2, 2015 09:05 PM
01civic20
Wheels and Tires
Dec 13, 2007 02:09 AM
Boilermaker1
19
Mar 26, 2005 10:24 AM
rijowysock
Jul 5, 2004 12:00 PM
IrockCivics
Apr 5, 2004 12:30 PM
