Notices
Wheels and Tires Post your wheel and tire related questions here.
Rear brakes squeek a little?
Old Nov 19, 2007
01civic20's Avatar
01civic20 is an unknown quantity at this point
Yo i got a 2001 honda civic ex thats fixed up. Just recently my rear brakes squeek a little, more noticeable when next to a wall or wutever. Brakes are perfectly fine, its just when i let off of the brake it does. I checked the rear brakes not to long ago and they still got some time till they need changed. Is it just simply rubbing against something stupid or need to clean or greased up or something? Is it easy if so?
Old Nov 19, 2007
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
Re: Rear brakes squeek a little?
it could be the warning squeak that is letting you know they need to be changed.
Old Dec 12, 2007
Xhondatech's Avatar
Xhondatech is an unknown quantity at this point
yur brakes prolly need to be greased.. when they service those cars the tech is supposed to lube between the shoes nad the backing plate.. if it id doing it when u let off the brake and thats it... then thats it.. just have the end of each shoe between the shoe and the backing plate greased.. BUT JUST A LITTLE BIT!!! if u put to much u cant totally destroy the brakes.. youll get grease al over them and the parking brake wont work the way its supposed to.. hope that helps you out good luck
Old Dec 13, 2007
smithyjoe's Avatar
smithyjoe is an unknown quantity at this point
replace your pads...
7thgensurvivor
38
Aug 29, 2015 11:50 AM
DAC
Jun 18, 2015 10:00 PM
MamaBear2015
Jun 11, 2015 07:33 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
Andy
Dec 29, 2001 07:32 AM
