Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Will 16” rims fit on a 2007 EX 4DR?
Old Apr 10, 2023
christian420's Avatar
christian420 is an unknown quantity at this point
Might be a silly question but I am not a car guy.
Currently on 17” 205/55 R16 91H.
found a set on market place that are on 16” honda rims 205/55R16 91H.
Will these work?
Old Apr 10, 2023
Re: Will 16” rims fit on a 2007 EX 4DR?
both are the same tire size?
you will need to check off-set of the wheels
Old Apr 10, 2023
well, i measured my rims with a tape measure and got 17” but the tire itself says r16 so I am slightly confused.
Edit: To clarify, my car has 17”rims measured with a tape measure, the tires on the 17” say r16. So either im using this tape measure wrong or i have the wrong size tires on my rims.
The new set of rims and tires are 16” rims with r16 tires
Edit 2: Okay so Im assuming I'm just measuring wrong. My friends car is sitting on 18.5” rims but when u measure it it comes to 19.5 so it seems like I'm not measuring correctly.
Old Apr 10, 2023
just go with what is written in the tires...
Diameter is measured at the tire beads, the lip height does not matter
honda uses mostly same off-set, so maybe safe?
check if the number of studs are the same, 4 or 5 lugs
Old Apr 10, 2023
Colin42's Avatar
Could always bolt one on to test. 16" should be fine though
Spyris
May 21, 2014 07:48 PM
randy1515
Nov 3, 2013 02:26 PM
Incomple
Jun 24, 2012 08:32 PM
Derek-CEO
Sep 19, 2006 11:01 PM
