Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Upgrading to larger brakes but keeping 16 in rim size
Old Jul 6, 2025
CIVx22's Avatar
CIVx22 is an unknown quantity at this point
Hi
I'm looking for an easy gain in braking power as I drive my LX on the freeway and speeds can go from 75 to abruptly 20 mph.
I researched online that the Acura RSX 06 has 282mm rotors which are larger than my 262 LX rotors and I want to upgrade to those. I read that I just need the RSX caliper bracket to make the larger brake pad fit on the larger rotor however, I can't seem to find a caliper bracket that fits the pads.
I purchased akebono ACT 621A pads and 14-1435 caliper bracket but the pads wont fit inside the bracket. They fit without the shims, but not when the shims are in place.
Today I had the wheel off and noticed these akebono pads are almost the same thing as my original pads, the only difference is its slightly wider by a 16th of an inch which makes me think these pads are not correct.
Also, when I put the pads on the 282mm rotor, I see they dont bite the full rotor, meaning some of the rotor is exposed.
Does anyone know where I can find the right caliper bracket and pads that will fit?
Also, does anyone know if everything will clear inside a 16in rim with the 282mm setup?
Thanks
rgar98
Apr 3, 2015 02:35 PM
GeoJeff
Wheels and Tires
Oct 25, 2008 11:26 PM
2k2civicsedan
Jan 26, 2007 05:06 PM
milk242
May 31, 2006 01:03 PM
Pn0ybOiLiKehOy
Oct 11, 2005 08:25 PM
