Notices
Wheels and Tires Post your wheel and tire related questions here.
1992 VX disc and pad trouble
Old Oct 25, 2008
GeoJeff's Avatar
GeoJeff is an unknown quantity at this point
Howdy.
I hope someone can shed some light on the following problem.
I am replacing the rotors and pads on my daughters 1992 Honda Civic VX.
One side of the right rotor was too far abraded to machine. She drove the car until she could not stand the noise! Nursing student!
We went to NAPA and got 2 new rotors and new pads.
The caliper would not fit over the rotor and pads. The piston was well back and never an issue. I removed the shims and not much better. I was able to get the thing together but the car would barely move!! Never saw this in 40 years of repairing my own cars. I decided to put one of the used pads back on. Seemed fine.
Then the other side! The rotor was no doubt worn but was smooth as glass. I did not install the new rotor, only the pads. Maybe I should try just to see it this side goes together. Anyway, I took the car for a very short drive. There was a horrible grinding noise on the left (drivers) side (old rotor, new pads).
I removed the wheel. It is rubbing slightly on the outside "corner" of the caliper. There was a nice shiny "groove" inside the wheel, and a silvery rub mark on the caliper.
We tossed the old disk pads from the other side at NAPA! If they can find them I might replace the new outside pad with the old, partially worn pad.
Can I file down the caliper? Just a little bit. How much clearance must there be between the wheel and caliper?
I really appreciate the help. Many thanks.
J
Old Oct 25, 2008
Re: 1992 VX disc and pad trouble
make sure you have the right size pads. older civics are really picky and alot of times the "economy" pads that auto parts stores have are slightly different size. you may even have to get pads from the honda dealer if you still can. i would really recommend changing both rotors to new ones to eliminate brake bias. do not file the caliper down.
SammySC
121
Apr 7, 2017 07:43 PM
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
BJB
Sep 14, 2015 11:16 PM
