Upgraded Brakes
Rep Power: 0 Upgraded Brakes
What are the best type of rotors to buy? Slotted or crossdrilled? And what brand? I want to upgrade my brakes with aftermarket ones but I don't want to replace the calipers. If I upgrade the brakes will I need a caliper relocator bracket? Also I want to upgrade my brake pads. Any advice would be greatly appreciated. Thanks.
Rep Power: 256 Don't get cross drilled. Slotted is fine but OEM or brembo blanks will be sufficient. As for pads you have alot to choose from but most ppl choose hawk pads. Check out the power slot rotors and hawk pads combo from dezod. These are direct replacements and you won't have to change the position of your caliper. Another nice upgrade is getting stainless steel brake lines. Good luck. FYI I'm using EBC greenstuff pads and they're really good with light dust.
Rep Power: 0 the crossdrilled and slotted is a preference choice.... it just takes in the break dust and doesnt throw the dust all over your rims. i prefer the crossdrilled myself
my friend has brembo rotors & stock calipers on his 240sx and they are A-MAZING! It's an amazingly big difference!! If you only upgrade the rotors just make sure they are the same size as what's stock, im not sure what size it is on our car... but research.
as for brake pads... idk
-Joe
01' Civic HFP
-Joe
01' Civic HFP
Rep Power: 226 if you go big break rotors, then thats the time you need the relocator. as for slotted vs drilled, i hear that drill ones cracks (make sure to get a good brand) and slotted get dusty.
Rep Power: 265 Unless you're racing, or just beating the **** outta your car, you shouldn't need drilled or slotted rotors. If you insist on one or the other, get slotted, probably Powerslot, as someone else mentioned. Personally, when I do my brakes in the spring, i'm going with just brembo blanks, and hawk pads.
Autocross Junky
Rep Power: 356 Rotors arnt going to make much of a difference one way or another in regards to stopping power. And for a street car, Drilled/Slotted/Blank/what ever... It matters even less. Pick one you think looks the best, as thats about all any of them are worth on the street. If you are tracking your car (Open track not autocross) then AVOID DRILLED ROTORS, but slotted may be usefull as they can help reduce the chance of glazing your pads over multiple hard stops. But like I said, for the street it really doesnt matter much and pick the one you like the looks of.
Now changing your pads will actually alter the "feel" of the brakes as well as how hard you can run the brakes with out fade. Hawk HP's are good as well as HPS's. Axxis makes some good pads aswell. My personal fav for street setups is Cobalt GT's, but I've also run Porterfield R4s's. Some pads dust more, some are more prone to squeak.. but thats pretty much your only concern for a street car
Note: Nither pads, fancy rotors, Huge calipers or what ever other "trick" brake parts you add will actually signifigantly shorten your stopping distances (60-0 distance). They will however alter how the "feel" of the brakes and how much preasure you need to push on the pedal in order to reach the tires maximum brake Torque. So, if you actually want to improve your stopping distances... you need to get grippier tires.
Official Wish He Knew It All
Rep Power: 217 Brembo Blanks + Hawk HPS Pads= the best brake package for our cars that actually works.....I have had them for a month now and I love them. Great stopping power....I used to have the cross-drilled/ slotted rotors from ebay...they sucked..ruined by pads and the rotors were chewed apart in 2 months...
I just installed a set of powerslot slotted and hawk hps pads and they seem to "feel" alot better. I picked them up through summit racing for about 200 shipped. Also I just did the ss brake lines and they reduce the sponginess in the peddle.
Rep Power: 0 EBC Brakes | Slotted Brake Rotors | Performance Brakes | Racing Brakes
EBC have good roters and pads, amazing difference in braking power. U could go for some green stuff.
Autocross Junky
Rep Power: 356 Easy, Why spend Money on something that really isnt helping you stop better?
Slotting is really only usefull in helping reduce the chance of glazing your pads... but think about it. When's the last time you actually glazed a set of brake pads?
honda.lioness
08-06-2015 11:58 AM
DerbyDad03
07-27-2015 11:34 AM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
